Old 28-09-2011, 04:08 PM   #1 (permalink)
avichandana20000's Avatar
Default Case fan choice
i need a case fan from CM.
Out of many i have come down to two:
Cooler Master 120mm fan 90 CFM Green (R4-L2R-20CGF-GP)
Current (Ampere) : 0.35A ± 10%
Speed (R.P.M.) : 2000 RPM
Air Flow (CFM) : 90 CFM
Air pressure (mmH2O) : 3.04 mm H2O
Fan Noise Level (dB-A) : 19 dBA
Bearing Type : Long Life Sleeve
Fan Life Expectancy : 50,000 hrs
XTRA FLO
Speed (R.P.M.) : 800 - 2200 R.P.M ± 10%(PWM)
Air Flow (CFM) : 34.02 – 93.74 CFM ± 10%
Air pressure (mmH2O) : 0.43 – 3.30 mmH20
Noise : 15 - 38 dBA
Bearing Type : DynaLoopTM Bearing
Fan Life Expectancy : 40,000 hours
Everything regarding xtraflo is good except the life Expectancy.
10,000 hrs is more than a year. which one to get? (kassh xtraflo comes in green)
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 28-09-2011, 04:31 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Case fan choice
i don't think there is much difference in specs the chages r only cosmetic btw the XF looks cool in idle also the difference between two is 100-150 bucks my vote goes to the 1st one green will look more cool when in operation
also u won't use them more than 3 yrs would u
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 28-09-2011, 04:36 PM   #3 (permalink)
thanks. u have just told my mind's word.
so i have thought of taking both. green will be front intake and xtraflow for top exhaust in my cabb 310 elite which has already been modded with a blue light in the floor.
Old 28-09-2011, 04:46 PM   #4 (permalink)
mithun_mrg's Avatar
cool so that will be a tricolor cabby buddy please post the pics when done
Old 28-09-2011, 05:52 PM   #5 (permalink)
Will do for sure. But you know 310 needs be modded for attaching the top exhaust. any idea how to cut the ceiling in circular shape without buying a dremel?
Old 28-09-2011, 06:07 PM   #6 (permalink)
mithun_mrg's Avatar
how about electrical welding
Old 28-09-2011, 06:10 PM   #7 (permalink)
good. will ask them. but they are not very professional type.
Old 28-09-2011, 06:18 PM   #8 (permalink)
mithun_mrg's Avatar
make it a little bit smaller & do the finishing ur self with a sandpaper
Old 28-09-2011, 06:31 PM   #9 (permalink)
ok now the main problem i am facing is the availability of XTRAFLO. IT DEPOT does not have it.
Old 29-09-2011, 10:33 AM   #10 (permalink)
mithun_mrg's Avatar
try at ebay its available there i think @600bucks
Old 29-09-2011, 12:28 PM   #11 (permalink)
every time this happens with me. whenever i want to buy either it is not available or is overpriced. damn.
Old 29-09-2011, 12:57 PM   #12 (permalink)
mithun_mrg's Avatar
sorry buddy i think its not available at ebay try this
Theitdepot - Cooler Master XtraFlo Case Fan (R4-XFBL-22PR-R1)
Old 29-09-2011, 02:34 PM   #13 (permalink)
what to try. The first site i have seen is this.i have already mailed them and they declared that is out of stock. and it is still showing in their site. Most unprofessional database updation.
Dear sir
Hi,
Greetings!
Thank you for writing in.
We are sorry to inform you that Cooler Master XtraFlo Case Fan (R4-XFBL-22PR-R1) product is currently out of stock.
Thank you for choosing Theitdepot!
Have a nice day.
For further assistance, you can call us on 044-45504416 or write to us.
Thanks & regards,
naseem
Theitdepot Customer Support
Not in Primeabgb, ITWARE. SMC INT, DELTAPAGE, not even in EBAY. MD COMPUTER is messing up XTRAFLO with BLADEMASTER, NOT IN VEDANT. NOT IN NEWEGG, lynx is showing it but don't know in stock or not.It is written there:
If Its " Out Of Stock " We Can Get This Even On Case To Case Basis
What does this mean? and i also do not want to buy anything from them for their bad reviews.
I have also written a mail to the CM EASTERN HEAD regarding stock availability. no answer.
Any other site you know where i can try?
Old 29-09-2011, 03:56 PM   #14 (permalink)
mithun_mrg's Avatar
u can try calling at lynx they r not that bad i have purchase 4-5 times from them
Old 29-09-2011, 04:48 PM   #15 (permalink)
need to wait . after puja vedant may arrange for it. Also requested ITDEPOT to arrange the same.BTW what that sentence mean
Old 29-09-2011, 05:13 PM   #16 (permalink)
mithun_mrg's Avatar
can't say btw best of luck for the fan & happy puja in advance
Old 29-09-2011, 05:14 PM   #17 (permalink)
Gamer
They can get the fan for you individually.
ArjunKiller is offline   Reply With Quote
Old 29-09-2011, 05:17 PM   #18 (permalink)
i WILL BUY those fans for sure. Happy puja to you not for me because i need to come office all the days next week.
means they will buy just one fan for me if ordered.
Old 29-09-2011, 05:18 PM   #19 (permalink)
Gamer
We have holidays!
Yes they will.
- by c4u
