Old 27-09-2011, 10:09 PM   #1 (permalink)
avichandana20000's Avatar
Default APC BACK UPS ES 650Va no beep
My UPS is giving perfect backup but there is no beep sound which is default during battery backup.(four beeps per interval) this i have come to notice 2 days ago.
what could be the problem?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 28-09-2011, 08:25 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: APC BACK UPS ES 650Va no beep
the beep comes from the buzzer i.e a small speaker used also in the mb may be the buzzer has gone kaput
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 28-09-2011, 10:17 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Actually there is some setting which has gone off. Read the manual, it tells how to enable it again.
asingh is online now   Reply With Quote
Old 28-09-2011, 11:41 PM   #4 (permalink)
in the Software i.e. Powerchute personal Edition there are 4 options under NOTIFICATION
1)enable Battery Backup alarms all time
2)Disable Battery backup alarms all time.
3)Disable battery backup alarms when PC is off or Hibernate
4) between ......Hrs to ......Hrs.
in my case somehow the second option was checked.
Thanks to all.
- by c4u
