Old 27-09-2011, 02:42 PM   #1 (permalink)
vir
Exclamation write protected
I have a 4GB i-ball pen drive which is write protected. I can read the files but i cannot delete/move/copy from the pen drive, even formatting s not possible. how do i remove write protected and format the drive?
Thanks!
vir is offline   Reply With Quote
Old 28-09-2011, 08:27 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: write protected
please give details what pen drive do u have i.e brand/model etc
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 28-09-2011, 01:01 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@vir: is there any write protected button/switch on pendrive?
Old 29-09-2011, 04:15 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - which OS you are using ? if win 7 just click on the pen drive icon in explore and click on Take Ownership.
If you are facing this error in multiple OSes then just try format the pen drive using command prompt.
ToPsPeEeD = FaSt BuT StEaDy
