Hi Below is a screenshot of Open Hardware Monitor of my PC Temperatures.
I am having Zebronics Bijli Cabinet having 1 Front LED Fan(Intake), 1 fan at the back(Exhaust), 2 fans on side panel (Top is Intake, Other is exhaust), I also have Sapphire Radeon HD 6750 1GB GFX Card, also stock AMD CPU Cooler. I use Cooler master HTK-002 thermal compound and change it every 3-4 Months.
Please see the temperatures below and tell me if they are normal. I have used open hardware monitor taken this screenshot after using the PC for 2 hours of browsing, DVD burning, Played DIRT3 for 20 mins, Also converted some videos etc..
AMD Athlon II X4 635|Gigabyte GA-MA785GM-US2H|4 GB DDR2 RAM|4TB Storage|Sapphire HD 6750 1GB GDDR5|AOC 2236VW|Gigabyte SuperB 460W|Zebronics Bijli|VS 4121|HD180
Re: Please check my PC Temperatures, Are they Normal?
it is normal.but still run an half an hour test of prime 95 and post results here.btw there is no need to change the thermal paste once in a 3-4 months.once applied tim will live atleast for 2-3 years.so don't change it frequently.
