Old 23-09-2011, 01:07 PM   #1 (permalink)
Fell Off the Asembly Line
sunny4691's Avatar
Default UPS Problem
Guys my current UPS is almost dead, it gives no backup and it keeps restarting my pc when the voltage flickers a bit which happens a lot in my area, i have also changed the battery but it is not able to charge the battery, so i was thinking of buying a new ups, and wanted to know is Intex 1000VA better than Microtek 600VA. APC and other good brands are not available here.
sunny4691 is offline   Reply With Quote
Old 23-09-2011, 01:18 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: UPS Problem
from where r u in ASSAM apc is available in assam
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 23-09-2011, 01:44 PM   #3 (permalink)
sunny4691's Avatar
I live 40kms away from Dibrugarh in Moranhat
Old 23-09-2011, 06:28 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
Go for Intex 1 KVA without any second thought.
d6bmg is offline   Reply With Quote
Old 24-09-2011, 07:24 AM   #5 (permalink)
mithun_mrg's Avatar
in dib u know umang opp. to them is a computer shop contact them they can supply APC
Old 24-09-2011, 07:51 AM   #6 (permalink)
sunny4691's Avatar
Ye I know Umang and the opp. Shop to it, but I will like to buy it locally as it is very heavy, will also try to search for APC in my local shops. But how are these intex,frontech 1kva ups.
Old 24-09-2011, 08:38 AM   #7 (permalink)
mithun_mrg's Avatar
avoid intex,frontech btw luminous & microtek is also good there is no reason u can't get APC btw what is ur config do u really need 1KVA
Old 24-09-2011, 11:25 AM   #8 (permalink)
sunny4691's Avatar
Actually bro as am upgrading my whole computer i bought a cooler master UCP 900w psu, and when i plugged it in my ups and switched on the ups, the ups kept on restarting with the red led like it was taking its last breaths, and after that i directly plugged the psu instead of ups and it worked fine, the ups already cant withstand the load of local psu, so i think that 1kva will be a good choice.
Old 24-09-2011, 03:45 PM   #9 (permalink)
mithun_mrg's Avatar
then go for microtek its cheaper & better than others u mentioned btw buddy why did u go for that cm psu what is ur config
Old 24-09-2011, 06:03 PM   #10 (permalink)
sunny4691's Avatar
Ok will go for microtek. Actually I was looking for a used psu from many days..err... months and lastly got a good deal on this ucp psu so bought it, its almost brand new and 3yrs warranty left, and as I said earlier I am upgrading my whole pc so that's why buying parts one by one, and am thinking of going sli or crossfire in furture.
