Old 22-09-2011, 11:21 PM   #1 (permalink)
curioustechy's Avatar
Default Sudden shut down of laptop
last day while i was using my laptop all of a sudden system was shut down and restarted with a blue screen error.. it is like this
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 100000ea
BCP1: 85A39D48
BCP2: 00000000
BCP3: 00000000
BCP4: 00000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\092111-36488-01.dmp
C:\Users\agape\AppData\Local\Temp\WER-54569-0.sysdata.xml
curioustechy is offline   Reply With Quote
Old 23-09-2011, 05:31 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Sudden shut down of laptop
what application(s) your were using when this happened ?
Did you made any recent hardware or software changes ?
Use HWMonitor app and post a screenshot.
ToPsPeEeD = FaSt BuT StEaDy
Old 23-09-2011, 11:46 PM   #3 (permalink)
I was just copying some files from one location of the hard disk to another and playing a song in win media player... no recent hardware change... but i always installs and uninstalls different softwares... this is the HW test result
CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.8.0
Monitoring
Mainboard Model 3061 (0x000000CA - 0x00002108)
LPCIO
Hardware Monitors
Hardware monitor ACPI
Temperature 0 79°C (174°F) [0xDC2] (THRM)
Hardware monitor ATI I/O
Temperature 0 68°C (154°F) [0x44] (TMPIN0)
Hardware monitor AMD ADL
Voltage 0 0.90 Volts [0x383] (VIN0)
Hardware monitor Battery
Voltage 0 8.10 Volts [0x1FA4] (Current Voltage)
Capacity 0 47520 mWh [0xB9A0] (Designed Capacity)
Capacity 1 1037 mWh [0x40D] (Full Charge Capacity)
Capacity 2 n.a. [0x0] (Current Capacity)
Level 0 98 pc [0x2] (Wear Level)
Level 1 n.a. [0x0] (Charge Level)
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Turion X2 RM-74
Codename Griffin
Specification AMD Turion(tm) X2 Dual-Core Mobile RM-74
Package Socket S1 (638)
CPUID F.3.1
Extended CPUID 11.3
Brand ID 6
Core Stepping LG-B1
Technology 65 nm
TDP Limit 43 Watts
Core Speed 551.3 MHz
Multiplier x FSB 2.75 x 200.5 MHz
HT Link speed 1804.4 MHz
Stock frequency 2200 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 2.8x - 7.0x
VID range 0.750 V - 1.200 V
P-State FID 0xE - VID 0x22 - IDD 14 (11.00x - 1.125 V)
P-State FID 0x10E - VID 0x30 - IDD 6 (5.50x - 0.950 V)
P-State FID 0x20E - VID 0x3C - IDD 3 (2.75x - 0.800 V)
Package Type 0x2
Model 74
String 1 0x1
String 2 0x0
Page 0x0
CmpCap 2
ApicIdCoreSize 2
TDC Limit 28 Amps
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02004005h
Max CPUID level 00000001h
Max CPUID ext. level 8000001Ah
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00200F31 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x8000001A 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00200F31 0x20000CA0 0x0000131F 0xEBD3FBFF
0x80000002 0x20444D41 0x69727554 0x74286E6F 0x5820296D
0x80000003 0x75442032 0x432D6C61 0x2065726F 0x69626F4D
0x80000004 0x5220656C 0x34372D4D 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003028 0x00000000 0x00001001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x0000000E
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001A 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000020
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x8000018E 0x0000440E
MSR 0xC0010065 0x8000013D 0x0000604E
MSR 0xC0010066 0x8000011D 0x0000788E
MSR 0xC0010067 0x0000013D 0x0000604E
MSR 0xC0010068 0x00000000 0x00000000
MSR 0xC0010071 0x001D00E3 0x6800440E
MSR 0xC0010015 0x00000000 0x01000048
MSR 0xC001001F 0x04000010 0x00000000
MSR 0xC0010058 0x00000000 0xE0000011
MSR 0xC0010004 0x000011F0 0x2767F271
MSR 0xC0010070 0x00000000 0x0000440E
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02004005h
CPUID
0x00000001 0x00200F31 0x01020800 0x00002001 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC0010004 0x0000F913 0x6B3A39DB
Storage
USB Device USB Composite Device, class=0xEF, subclass=0x02, vendor=0x0408, product=0x03F0
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x1307, product=0x0163
USB Device Validity Sensor (VFS201), class=0xFF, subclass=0x00, vendor=0x138A, product=0x0001
USB Device HP Integrated Bluetooth module, class=0xE0, subclass=0x01, vendor=0x03F0, product=0x171D
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x0BC2, product=0x3001
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name ATI Mobility Radeon HD 4650 Series
Codename RV730
Technology 55 nm
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x103C)
Model ID 0x9480 (0x3061)
ACPI
ACPI Tree
_GPE
_L03
_L04
_L12
_L07
_PR_
CPU0
_PCT
_PSS
XPSS
_PSD
_PPC
CPU1
_PCT
_PSS
XPSS
_PSD
_PPC
_SB_
PWRB
_HID
_STA
SLPB
_HID
_STA
PCI0
_HID
_CID
_ADR
SCTH
RSMF
_INI
NBMS
MIDX
MIDR
NBMM
NBMR
NBMW
NBXP
NBXI
NBXD
NBXM
NBXR
NBXW
GFXM
GPPM
XPTR
_UID
_BBN
SUPP
CTRL
_OSC
TOM_
NBBR
BR3L
BR3H
NBBI
PARB
PX3L
PX3H
PX3S
PX3K
BR3X
BR3M
CRES
_CRS
MEMR
_HID
MEM1
_CRS
_PRT
PICM
APIC
AGP_
_ADR
_PRT
PIC_
APIC
VGA_
_ADR
SWIT
CRTA
LCDA
TV0A
HDTV
CV0A
_STA
_PSC
_PS0
_PS3
_DOS
_DOD
CRT_
_ADR
_DCS
_DGS
_DSS
TV0_
_ADR
_DCS
_DGS
_DSS
LCD_
_ADR
_DCS
_DGS
_DSS
_BCL
_BCM
_BQC
HDMI
_ADR
_DCS
_DGS
_DSS
CVTV
_ADR
_DCS
_DGS
_DSS
PB2_
_ADR
_PRT
DVGA
_ADR
SWIT
CRTA
LCDA
TV0A
HDTV
CV0A
_STA
_PSC
_PS0
_PS3
_DOS
_DOD
CRT_
_ADR
_DCS
_DGS
_DSS
TV0_
_ADR
_DCS
_DGS
_DSS
LCD_
_ADR
_DCS
_DGS
_DSS
_BCL
_BCM
_BQC
HDMI
_ADR
_DCS
_DGS
_DSS
CVTV
_ADR
_DCS
_DGS
_DSS
PB4_
_ADR
_PRT
XPCB
LKCN
LKST
SLST
XPRI
XPIR
XPID
XPEX
VC0S
XPDL
XPRD
XPWR
XPRT
XPLP
XPR2
NCRD
_ADR
PCFG
DVID
PCMS
_RMV
PB5_
_ADR
_PRW
_PRT
PB6_
_ADR
_PRW
_PSW
_PRT
PB7_
_ADR
_PRW
_PRT
PB9_
_ADR
_PRW
_PRT
PB10
_ADR
XPCB
LKCN
LKST
SLST
XPRI
XPIR
XPID
XPEX
VC0S
XPDL
XPRD
XPWR
XPRT
XPLP
XPR2
_PRW
_PRT
J380
_ADR
PCFG
DVID
SSID
D3EF
LAT0
ATRB
PMC0
_STA
_RMV
J381
_ADR
_RMV
J382
_ADR
_RMV
J383
_ADR
_RMV
J384
_ADR
_RMV
JADS
HPET
_HID
_STA
_CRS
USB0
_ADR
_S3D
_S4D
USB1
_ADR
_S3D
_S4D
USB2
_ADR
RHUB
_ADR
PRT0
_ADR
_UPC
_PLD
_S3D
_S4D
USB3
_ADR
RHUB
_ADR
PRT0
_ADR
_UPC
_PLD
_S3D
_S4D
USB4
_ADR
_S3D
_S4D
USB5
_ADR
RHUB
_ADR
PRT2
_ADR
_UPC
_PLD
PRT3
_ADR
_UPC
_PLD
USB6
_ADR
RHUB
_ADR
PRT5
_ADR
_UPC
_PLD
SMBS
_ADR
IRQF
RVID
GP53
GP54
GP55
GP56
GP57
GP58
GP59
GP60
R56H
GP64
GP70
GP71
GP72
GP73
D3EO
IRQK
IRQM
GP13
BMBS
SA1E
SA2E
HPAD
PMIO
INPM
DAPM
TM1E
TM2E
TM1S
TM2S
SLPS
MKME
PI3E
PI2E
PI1E
PI0E
MKMS
PI3S
PI2S
PI1S
PI0S
GE0T
GE1T
GE2T
GE3T
GE4T
GE5T
GE6T
GE7T
GM4C
GM5C
GM6C
GE7S
SPRE
UPME
RS3U
RSTU
TPDE
GEVS
SMBI
HSTS
HSSA
HCTR
HCMD
SLVA
SDT0
SDT1
SWRB
SRDB
STRT
COMP
KEL_
LPC0
_ADR
PSMX
DMAC
_HID
_CRS
COPR
_HID
_CRS
PIC_
_HID
_CRS
RTC_
_HID
BUF0
BUF1
_CRS
SPKR
_HID
_CRS
TMR_
_HID
BUF0
BUF1
_CRS
PS2K
_HID
_CRS
_PRW
_PSW
PS2M
_HID
_CID
_CRS
_PRW
_PSW
SYSR
_HID
_CRS
MEM_
_HID
MSRC
_CRS
EC0_
_HID
_UID
_CRS
ERAM
SMPR
SMST
SMAD
SMCM
SMD0
BCNT
SMAA
BATD
SW2S
WIN7
RFLG
CFAN
PFN2
WOLF
PFLG
BBDA
LIDE
TLDP
LIDS
TLID
RTMP
ECT1
ECT2
RG5B
BADC
BADV
BATP
MBST
MCUR
MBRM
MBCV
QBHK
QBBB
MBTS
MBTF
MBTC
MBNH
BA1C
RCDS
MCER
RPM1
RPM2
OCPL
OCPH
MCEA
DLYC
EBPL
DLYE
DBPL
PSKB
PSTP
PSBA
LANP
DLYT
BRTL
SARS
SFHK
SFAN
FNF4
BATO
BATN
BATF
_REG
BPOL
BPOM
_GPE
_Q09
_Q20
GBAS
_Q21
_Q80
_Q8A
VGMX
_Q0D
_Q0E
_Q11
_Q10
_Q15
_Q16
_Q8E
_Q8F
SMW0
SMB0
FLD0
FLD1
FLD2
FLD3
MUT0
SMRD
SMWR
GSHK
SSHK
DISS
SWII
GNSD
CPUS
KTWU
W7RF
CIR_
_HID
_STA
_CRS
_PRS
LCLM
CLMI
CLMD
CLGP
IDRG
TSTS
TINT
I2CC
GPIO
RGPM
P2P_
_ADR
PCPC
PCMD
IOW1
IOW2
PR48
PR49
PR4A
PR4B
_PRT
PIC_
APIC
SATA
_ADR
IDE_
_ADR
UDMT
PIOT
PITR
MDMT
MDTR
IDE_
PPIT
SPIT
PMDT
SMDT
PPIC
SPIC
PPIM
SPIM
PUDC
SUDC
PUDM
SUDM
GETT
GTM_
STM_
GTF_
PRID
_ADR
_GTM
_STM
P_D0
_ADR
_GTF
P_D1
_ADR
_GTF
SECD
_ADR
_GTM
_STM
S_D0
_ADR
_GTF
S_D1
_ADR
_GTF
ACEL
_HID
DEVP
CURS
_INI
_CRS
_STA
INIT
JACC
CLRI
ALRD
ALWR
ALED
ALID
ADSN
BCLT
LCBR
LEBR
SBCM
GBQC
BRXP
PIRQ
PIDX
PDAT
PIRA
PIRB
PIRC
PIRD
PIRS
PIRE
PIRF
PIRG
PIRH
DSPI
PRS1
BUFA
IPRA
IPRB
IPRC
IPRD
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKE
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKF
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKG
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKH
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
GSMI
S80H
BSMI
VTOB
BTOV
MKWD
POSW
GBFE
PBFE
ITOS
BAT0
_HID
_PCL
PBIF
PBST
BAST
B1ST
B1WT
_STA
_BIF
_BST
UPBI
UPUM
UPBS
IVBI
IVBS
ACAD
_HID
_PCL
ACWT
_PSR
LID_
_HID
_LID
QLB0
_HID
_STA
WMID
WCDS
CSMI
WSDI
HWMC
_HID
_UID
WMIF
WEID
WEDT
BUFF
WMI5
OB0_
OB1_
OB2_
OB3_
_WDG
WMAD
GDST
SDST
GDKS
GWLS
SWLS
GBIF
GBBT
GHKS
SHKS
GHKF
SHKF
HKFR
GBBV
GWDD
GSAS
GWSD
SWSD
GBBS
SBBS
_WED
W05W
WQAE
_SI_
_TZ_
TPC_
TPTM
TPAS
THRM
_TMP
_HOT
_CRT
_PSL
_PSV
_TC1
_TC2
_TSP
REGN
FMAX
FMIN
FRSP
FSSP
_REV
_OS_
_OSI
_GL_
SSMI
TRP0
DBG0
IO80
ACMS
INDX
DATA
BTWL
BTLS
WWLS
BWLS
IVIM
BRAC
BRDC
VRAM
DOST
PFID
RLFG
UDFG
WAKS
OFEA
FAWA
PSMI
APMC
APMD
PMRG
PMRI
PMRD
TM1E
TM2E
TM1S
TM2S
SLPS
CLPS
PWDE
MKME
PI3E
PI2E
PI1E
PI0E
MKMS
PI3S
PI2S
PI1S
PI0S
P1EB
GV6P
GV7P
GM0P
GM1P
GM2P
GM3P
GM8P
GM4P
GM5P
GM6P
GM7P
GPX0
GPX4
GPX5
GPX1
GPX6
GPX7
GPX2
GPX3
SPRE
EPNM
DPPF
FNGS
R617
RSTU
TPDE
WPNE
WPAG
GV7S
HECO
TPE0
TPE1
TPE2
TPE3
P1E0
PEWS
WSTA
PEWD
IOCC
RTCS
PCM1
IW1S
IW2S
OT80
PS48
PS49
PS4A
PS4B
PRWP
GPRW
PCFG
STB5
PT0D
PT1D
PT2D
PT3D
PT4D
PT5D
PT6D
PT7D
PT8D
PT9D
BAR_
PMBY
PMS0
PMS1
DET0
PRC0
SMBY
SMS0
SMS1
DET1
PRC1
PSBY
PSS0
PSS1
DET2
PRC2
SSBY
SSS0
SSS1
DET3
PRC3
EBDA
PIDV
SPTS
SWAK
TRMD
CHKH
TRAP
MBOX
PCI1
PCI2
PCI3
PCI4
PCI5
PCI6
PCI7
PCI8
NLCK
ZIPE
COMA
CAIO
CAIP
CAMD
CADA
COMB
CBIO
CBIP
CBMD
CBDA
FHSD
COMC
CCIO
CCIP
CCMD
CCDA
COMD
CDIO
CDIP
CDMD
CDDA
LPT1
L1IO
L1IP
L1MD
L1DA
LPT2
L2IO
L2IP
L2MD
L2DA
LPT3
L3IO
L3IP
L3MD
L3DA
FDDC
FDWP
HGMP
LGMP
MIDI
AZLA
AUDO
MODM
IDEC
SSED
PACT
SCFG
AMOD
IMOD
LCFG
IDLY
PMTP
PMIO
PMBM
PMTM
PSTP
PSIO
PSBM
PSTM
IDE0
IDE1
IDE2
IDE3
IDE4
IDE5
IDE6
IDE7
HIUB
LUBS
PLYT
EDCG
SDFY
SDTC
SDRP
SDCL
SDRC
SDRE
FC2L
FC3L
FCS4
APIM
HPTS
HPTA
EMAS
VGAO
SOFF
KBPO
MSPO
USBB
EVTL
SYBE
ETLC
AC30
TPMD
TPMO
TPMC
TPMM
TPCC
TPLC
TPLR
QBOT
QTBT
PBOT
M256
PEGF
ORTS
BMTP
BNPT
LNMT
NBTO
NABD
NEBD
NLBD
DFBT
NPSP
LANG
UACL
SUPS
DVET
S3RS
DAS1
DAS3
WKPM
WKMD
WKS5
HOUR
MINS
SECS
DOFM
NBTV
BTOD
SPVP
POPD
USPW
HDPW
KRSV
LIMF
LIMS
IGMT
PWST
PNOW
FNON
TRON
PCRR
C4EN
C43D
MPST
VTSP
VTFT
PFMP
PVAT
OHC0
OHC1
OHC2
OHC3
OHC4
EHC0
EHC1
SATE
EC1E
ESVM
MCLC
MCLV
HTFR
HTWD
GSPL
P2G2
P2LA
P2LW
P2SP
P2LI
P2CM
P4G2
P4LA
P4LI
P4CM
P5G2
P5LA
P5LI
P5CM
P6G2
P6LA
P6LI
P6CM
P7G2
P7LA
P7LI
P7CM
P8LA
P8VT
P8CM
P9G2
P9LA
P9LI
P9CM
PAG2
PALA
PALI
PACM
UMAR
CPST
OSCS
SSSW
OBLS
CRSV
FDLY
CDBT
FPBT
FF11
CPBT
CPTR
DSME
D3E_
FANO
VGAF
OSFG
DSVM
SEHD
WA4B
ORSV
DRSV
ECON
KBWU
TPWU
NVST
SMIF
PRM0
PRM1
BRTL
TLST
IGDS
LCDA
CSTE
NSTE
CADL
PADL
LIDS
PWRS
BVAL
ADDL
BCMD
DID_
INFO
RESD
WDI0
WDI1
WDI2
WDI3
WSI0
WSI1
WSI2
WSI3
DCKS
WID0
WID1
WID2
WID3
WID4
WID5
WID6
WID7
PPCM
PPCN
NCPU
MCPU
ECPU
EXTM
CMTF
CMTI
CMTO
TOML
TOMH
CEBP
C0LS
C1LS
C0HS
C1HS
SCMP
WNOS
CKOS
MYOS
HTTS
SEQL
OSTB
TPOS
LINX
OSTP
_S0_
_S3_
_S4_
_S5_
GPIC
_PIC
SAV0
SAV1
_PTS
S34E
S45E
_WAK
S34W
Old 24-09-2011, 04:25 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ it would be great if you can post a HWmonitor Screenshot - no the whole log
BTW, check yiur HDD for Bad sectors with HDTune and Ram modules with memtest app and post the results.
Old 24-09-2011, 11:53 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
OMG thats a huge list I have to scroll to the bottom to read to end...
pls edit the post & post the screenshot instead...
& it seems u r using Service Pack 1?which OS r u using?
the BSOD might be due to RAM or GPU issue...sometimes HDD also cause that due to Bad sector
Old 25-09-2011, 03:27 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ Hid that Huge ACPI list
HE is using Windows 7 with SP1 ( OS Version: 6.1.7601.2.1.0.256.1 )
The Temp looks a liitle too hot
now waiting for Op to post the image so that we get some clear idea about tempo and volt readings.
@ OP - are you facing this issue after installing SP1 ? If so then update all the Hardware drivers.
