Old 22-09-2011, 08:37 AM   #1 (permalink)
Wink Sony DVD R/W
Hii
On Monday i purchased a new PC which which i got a Sony DVD R/W, but the problem is the dvd r/w is not detecting any autorun for any dvd. i mean when i insert a game dvd it is taking too long for me to start the Setup and setup also takes too long to begin.
neither i can copy anything.
same dvd works fine on my laptop.
The DVD R/W is ad7260s by Sony.
the driver version shown by update utility of sony is 1.61 and the driver on the website is 1.03.
so help me out quickly.
thanks in advance
Intel i5-2400 | Intel H67BL | MSI R6670 | Cooler master 500w | Sony DVD R/W | Corsair 4G.B. DDR3 1333Mhz | WD Cavair Green 1T.B. | Windows 7 Home Premium | Logitech Wireless K260 | HP W1907 |
DOST_FRIEND59 is offline   Reply With Quote
Old 24-09-2011, 11:15 AM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Sony DVD R/W
for autorun >> r-click drive >> autoplay tab >> check prompt me option.
try cleaning the dvd & insert it. also your antivirus is scanning dvd.
... W H O T ...
ax3 is offline   Reply With Quote
Old 24-09-2011, 11:32 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@DOST_FRIEND59: which anti virus are u using on desktop & laptop?
Old 26-09-2011, 10:25 AM   #4 (permalink)
thanks for the reply i will check whether after turning off my antivirus will i be able to read DVD CD.
Old 26-09-2011, 10:29 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
do not turn off anti virus to simply run the autorun file..coz autorun.ini the major culprit of spreading viruses....
if u r 100% sure that the CD/DVD u r reading is free from viruses then only disable the anti-virus...otherwise not..
Old 27-09-2011, 04:39 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - try a linux distro CD/DVD and see how much time it needs to get to the desktop - if the DVD drive has some issue the linux distro will take too long ( to show desktop ) or will not load at all.
Or else try a good cd/dvd which content is virus free and you know for sure ( like mobo driver CD ) and try copying the entire disk contents into HDD and see how much time it takes.
ToPsPeEeD = FaSt BuT StEaDy
