Old 21-09-2011, 10:07 PM   #1 (permalink)
Wink Hp w1907 turns off
Hii
i am using Hp w1907 for past 3 years but since past few days my monitor turns off automatically and restarts.
this issue was with my old PC but a couple of days ago i bought a new PC and still the problem persists.
i am using at 1440*900 resolution.
using at my laptop the problem is still there.
at laptop i am using at 1152*720 resolution.
since it's first day i am using it at 1440*900 resolution and i had no problem.
so please help me out quickly as now the problem is increasing and i am not able to work
DOST_FRIEND59 is offline   Reply With Quote
Old 21-09-2011, 10:12 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: Hp w1907 turns off
Its probably overheating.
Try to lower the refresh rate.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 21-09-2011, 10:25 PM   #3 (permalink)
my monitor does not support any other refresh rate other than 60 hertz
Old 21-09-2011, 10:33 PM   #4 (permalink)
Ishu Gupta's Avatar
Try to clean it.
Try a different cable/port.
Hard to say whats wrong with it.
Old 21-09-2011, 11:25 PM   #5 (permalink)
i already tried changing cable and on different electricity socket too but still no luck
Old 22-09-2011, 07:23 AM   #6 (permalink)
mithun_mrg's Avatar
is the monitor connected to a ups if yes then is the power supply of the monitor is provided by an adapter or directly anyways i think its a hardware fault u need to take it to the service center for repairs
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 22-09-2011, 08:13 PM   #7 (permalink)
i think i figured out the issue the power button on the top has gone faulty. so i think the monitor needs to be replaced but i don't know whether it is still in warranty.
Intel i5-2400 | Intel H67BL | MSI R6670 | Cooler master 500w | Sony DVD R/W | Corsair 4G.B. DDR3 1333Mhz | WD Cavair Green 1T.B. | Windows 7 Home Premium | Logitech Wireless K260 | HP W1907 |
Old 23-09-2011, 06:34 PM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
if it is out of warrenty period, then, sadly there is no use of replacing the screen (i.e. monitor)
d6bmg is offline   Reply With Quote
