18-09-2011, 03:59 PM
Master KOD3R
UPS Overload Issue
Hi,
I just got myself a Microtek UPS 625VA for 1550/- @ Delhi.
For starters the UPS works fine if I unplug it, switch it on & then turn on my rig. Didn't test out the back up duration, but it works.
However if I switch it on, turn on my rig & then unplug it from the wall socket (hence simulating a sudden power cut), then the UPS overloads because of the sudden power requirement from the battery.
My rig config is in my sig. My decade old Luminous Bravo 600VA doesn't overload albeit doesn't give backup either (battery issues every 2months, hence substituting it)
So any suggestions? Did I get a bad egg of a UPS, is my CX400 using too much power, should I get the 800VA model or just get the 600VA APC (the only one available for 1900/-)
Any ideas?
P.S. UPS works fine if it's just the monitor & the speakers, it's when (or only time) I plug the PSU plug does it overload on power outage.
18-09-2011, 05:13 PM
BMG ftw!!
Re: UPS Overload Issue
APC 800VA is a good option for you.
Possible reason behind your problem: very poor efficiency of CX400 in its full load condition.
18-09-2011, 05:36 PM
Master KOD3R
APC is out of my budget will a Microtek do?
Thanks.
(WAAT! No my CX400W ~sigh)
18-09-2011, 06:53 PM
Off for a while.
If you are going with brands like microtek or intex, go atleast 1000VA, coz their efficiency sucks.
18-09-2011, 07:31 PM
Master KOD3R
^ It's not efficiency I'm after. Heck even 2minutes uptime is more than sufficient for me. But my current UPS fails to even switch to backup-mode during a power cut (it overloads & O/P is cut off)
18-09-2011, 07:40 PM
Off for a while.
^ Seems there's a problem in ur UPS or it isn't charged a bit. So it'd be a wise decision to go for a APC one. I have 600VA one, and its connected to my pc (a bit low to ur config, 20%), 22" FHD monitor, modem, and it takes load easily. But i'd suggest you to first check ur PSU with other system beofre taking any decision.
18-09-2011, 07:51 PM
Master KOD3R
UPS is charged for sure, plus the manual that came with it (yes I'm one of those folks) clearly states that as overload condition (continuous beep & constant red LED). Also it can support my rig, once I have turned it off before, then start my machine. CX400 doesn't seem to be the issue 'cause the problem does not happen upon boot, only on power outages. If CX400 would be drawing insane powers at boot up then the UPS would've failed then also, while already in backup mode. (plus it's Corsair, very low chance of failure).
It is not taking time to switch to battery mode as it never makes it to it, it overloads & cuts off all O/Ps before it can switch (some sorta overload protection the manual states).
Thanks
18-09-2011, 08:00 PM
Off for a while.
^ I just guessed PSU as the culprit, although chances are less for it, also for "no-charge".
I suggest you take the UPS to ur dealer as may be it'd b a faulty one.
18-09-2011, 08:20 PM
Master KOD3R
Well sadly that's what I'd be doing. Man it's heavy carrying that stuff by your own over public transport. The UPS works fine when it's just the Monitor & the Speakers, it doesn't seem to like my rig, lol.
Thanks for your help.
18-09-2011, 08:32 PM
Off for a while.
Yeah, carrying it is a big heck. But u gotta do it. Anyways gL
18-09-2011, 10:37 PM
Super Moderator
Originally Posted by nbaztec
Hi,
Any ideas?
The 625VA should be able to hold upto ~400W of backup. Of course your system will not load that much. Means UPS is bad.
18-09-2011, 10:51 PM
Master KOD3R
That's what I thought, other rig is bad hence am not able to test it. My other Intex Protector 600VA seems to handle my "this" (over)load scenario well. Should I get the 800VA one, just in case?
19-09-2011, 10:31 AM
Super Moderator
You can yea.
19-09-2011, 01:48 PM
you could have just replaced the battery of luminous in the first place. I replaced battery of my 4 year old numeric 600va ups as it was giving me 5 second backup, i replaced with the best version of exide, cost me 900rs, now it gives me 15min backup. my comp specs are amd x2 250, asus m4a78ltm-le, 17 inch crt, rest similar to yours.
19-09-2011, 06:13 PM
Master KOD3R
Well I tried it once, ~5min backup with 400/- battery on my ye olde rig (C2D E4300). And my current config is a bit more power hungry with the 125W proccy (though 625VA shud've sufficed). Still I didn't wanna take any chances so got a 800VA dual battery one (Microtek). Problem gone. Might be a faulty piece. I'm considering it a 1-time investment @ 2500/-
It's all batteries fr me from here on.
P.S. FYI for anyone reading this, the 800VA model is heavier & bigger, get a bigger bag. :-/
20-09-2011, 11:31 AM
change is constant!!
@nbaztec
congrats...
me too using 800va microtek. gives good performance.. before i was using it for lighting's.. 2 CFL bulbs. gives 2 hrs of backup.
now i am using it for PC. still not tested backup for PC. i guess it might give 30 min for PC.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
22-09-2011, 10:51 AM
what backup are you getting now with your new ups?
22-09-2011, 05:13 PM
Master KOD3R
Didn't get the chance to test yet.
