Old 16-09-2011, 06:28 PM   #1 (permalink)
Wink Recover data from dead pc
my pc was crashing for pas few days without any known reason and i had decided to replace it, so today when i started to back up my data to my Laptop it finally became dead and i am very frightened about losing everything i had collected in the past 3-4 years. most of them are videos and photos with my school and college friends and all the files on which i have worked in the past years on Autodesk Maya and Adobe Photoshop.
my harddisk is Seagate 160 G.B. sata.
please figure out some way that i can recover and transfer everything to my Laptop and save my hardwork.
thanks in advance....
DOST_FRIEND59 is offline   Reply With Quote
Old 16-09-2011, 07:11 PM   #2 (permalink)
Mmmph!!!
doomgiver's Avatar
Default Re: Recover data from dead pc
boot from a live linux cd/dvd/usb.
if you want instructions, do tell.
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 16-09-2011, 07:45 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@DOST_FRIEND59: u need a bootable CD/DVD to recover the data...
just use Linux Mint or Bart PE or Hiren's boot CD to recover data...
another method:
take out the HDD & connect it to frnds PC.
Old 16-09-2011, 08:51 PM   #4 (permalink)
Wink Re: Recover data from dead pc
you do not understand dead pc means the pc doesn't start at all so i am not able use any bootable disc or anything and i was gonna new pc so i was backing up my whole data but as soon as i started back it has become dead so please give me some way i can connect my harddisk to my laptop and backup everything.
can i use sata to usb converter cable and if i can then where to buy and how much will it cost
Old 16-09-2011, 10:12 PM   #5 (permalink)
Mmmph!!!
doomgiver's Avatar
1. get an external case for the hard drive (the sata->usb cables may be included)
2. put your 160 gb disk in the case
3. connect to laptop
4. get your stuff back.
you should have told us taht the pc was not working.
is the motherboard light on (the small led)?
have you checked your power supply?
case will be 500-1000. cables/convertor around 50-500.
Steam : doomgiver
Old 17-09-2011, 09:25 AM   #6 (permalink)
Overclocker @ 4.8 Ghz
esudip's Avatar
1) Connect your HDD with another Working PC
OR
2) Boot from any LIVE Linux CD and recover data to USB drive !!!
OR
3) Purchase a USB HDD case for your HDD and connect it to your Laptop !!
esudip is offline   Reply With Quote
Old 17-09-2011, 10:41 AM   #7 (permalink)
dead PC doesn't boot.
but it'll cost 300-500 bucks.
Old 17-09-2011, 02:14 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
then use another method given by me....or external HDD case.
yes..use external casing for HDD
Old 18-09-2011, 01:42 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
@OP: buy a sata to usb converter @ 300/- and then recover those data.
Or go to any friend's place & recover your data via his/her PC.
d6bmg is offline   Reply With Quote
Old 24-09-2011, 11:26 AM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
wanna save money >> go to frds place [suggested by all] bt only if he doesnt mind keeping his pc ON for longtime for you.
imo, best option is get external casing & do it @ your place only
... W H O T ...
ax3 is offline   Reply With Quote
Old 25-09-2011, 12:01 PM   #11 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Just get the cables, it'll cheaper. Plus, you may still be able to use that 160gbon the HDD.
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline   Reply With Quote
