16-09-2011, 01:41 PM
Buzzz Sound Coming From Speaker
I have A MSI Z68A GD65 B3 Motherboard which has realtek ALC892 Sound Chip....the Problem is that I Get Continuous Buzzz or zzzzz Sound From My Speakers.... My Speakers are fine and Working with other devices.... and Hence cant get rid of Buzzing sound.....There may Be a Problem in Hadware or software...Please Help.
16-09-2011, 02:08 PM
Re: Buzzz Sound Coming From Speaker
@Ayuclack, have u installed the latest audio drivers?? Which version are u currently using?
16-09-2011, 02:40 PM
Ya I Updated It With The Latest Driver From MSI Website but still Getting the problem
Even getting Buzzing sound at BIOS Menu
16-09-2011, 03:08 PM
1. Are you sure that the speakers are good? Check with any other speakers or earphones.
2. Is that a constant buzz or occasional?
16-09-2011, 03:56 PM
is ur pc properly grounded i.e check if the earthing is ok
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
16-09-2011, 05:47 PM
Speaker ,Audio Working Fine In Mac OS but I Am Getting Buzz sound in Windows....Just disassembled The Computer ...Reassembled It and Done Every Hardware Things But No Use...It Works Fine With MAC And Ubuntu...and My Computer Is Properly Grounded Too
16-09-2011, 05:52 PM
BMG ftw!!
1. Check the ground cable as mentioned by mithun_mrg.
2. Check whether connection between speakers and mobo is right or not (if its loose)
3. Check your speaker's quality.
4. Check whether any signal is interfering your speakers or not.
5. Place your speakers a bit away from your UPS.
16-09-2011, 06:17 PM
Checked All Cables
Speaker Is Working Fine With iPod and Laptop
I Dont Have A UPS
Something Is Wrong With The Driver
Anyone With ALC892 ??
16-09-2011, 07:13 PM
if the problem is with driver, you would'nt get that buzzing sound in bios menu. I has similar problem, the actual culprit was the psu.
keep your speakers on and shutdown the pc with main switch still on and report back if you still have the buzzing sound.
16-09-2011, 07:46 PM
No Buzzing Sound Then...
Buzzing Sound is Some Times In The BIOS Menu Mainly When I Shutdown After Using Windows..
16-09-2011, 08:00 PM
Adam young
may be it could be some electricity problem.
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
16-09-2011, 08:07 PM
Na But On Same PC It Works Fine On MAC
16-09-2011, 08:19 PM
Adam young
then try to reinstall all drivers.if that doesn't help and you are sure that it is windows problem then reinstall the windows.
-Rifleman's Creed
16-09-2011, 08:39 PM
Just re installed Windows,,,,The Buzzing Sound is Reduced But Still Getting A Little Buzzz..
17-09-2011, 07:44 AM
@op if u have 2.1 speakers just try shuffling the output ports on the mb since it is 892 the output can be configured manually
17-09-2011, 11:12 AM
How ??? Manualy... And after formating windows the buzz sound had gone but after installing msi drivers it comes back
17-09-2011, 12:26 PM
Adam young
then install the sound driver from the sound card owners website.
-Rifleman's Creed
17-09-2011, 03:50 PM
Sound Worked Perfecly Fine after Installing Windows....
Next Giving A Little Bit Of Problem...
Installed All Drivers Except Sound Realtek Drive...Working Fine....
Installed windows update and Gta 4
Problem Started In Playing GTA 4 and The Buzz sound Continous
Does it Have Any Thing To Do With The Heating Up Of Computer and What should be the frequency and bit rate to be used.. with Creative SBS A335..
17-09-2011, 04:22 PM
#19 (permalink)
@op while the pc on unplug the speaker jack from the MB the task manager a message will pop "a jack has been unplugged" insert it to any other Orange,Black etc excluding the ping/blue jack a popup will come select line out/front speaker out & then see if the buzz persists
else remove all the sound drivers including the THX software if u have installed reboot and install from here if ur using win7 32 else change the os type
http://www.msi.com/product/mb/Z68A-G...r&os=Win7%2032
i doubt its a driver problem because u mentioned it happened in bios also
Try these & get back
17-09-2011, 06:19 PM
#20 (permalink)
After Doing All That The Buzz has Gone...I Thing It Has To Do Some Thing With Heat Up of Computer... or any Driver??
17-09-2011, 10:16 PM
#21 (permalink)
Adam young
congrats for your rig getting corrected.
-Rifleman's Creed
18-09-2011, 07:26 AM
#22 (permalink)
Particular That It has some to do with the heating Up.....any way its fine now
18-09-2011, 01:40 PM
#23 (permalink)
BMG ftw!!
Its nice to hear that your problem is gone.
19-09-2011, 10:55 PM
#24 (permalink)
in case the buzzing noise comes back, you can try one more thing - if you can see the front mic option, mute it. i had a problem like this quite a while back. the above method rectified it.
28-03-2012, 02:23 PM
#25 (permalink)
Buzzing Is Back What To Do ...
Just Formatted Windows for That Two Times But No Luck
Even Tried 2 Different Speaker But No Luck
Used Same Speakers On Laptop And They Work Like Charm
28-03-2012, 03:46 PM
#26 (permalink)
How is the gadgetry connected? What load is there on the UPS? Is the cable interfering with many others in a tangle? Does moving/handling/repositioning the cord to the mobo socket show any change?
One: { Intel i5-2500, Intel DH67VR, 2x4GB DDR3 1333MHz, 1TB, LG supermulti External, Flatron w1943SE, ... }
Two: { Pentium D 805, -----, -----, 200 or 120 or both GB :D, -----, ... }
Three :D: { Pentium III 900MHz, Intel D815EEA, 2x256 MB 100 MHz, 40 GB, ... }
28-03-2012, 04:11 PM
#27 (permalink)
I Dont Have A UPS PC Is Directly Connected To Power Socket
Just Today I Connected my Bravia KLV 40 V 550 A To The PC using Aux and The Buzzing Sound Was Still Coming From TV Speakers....
The Buzzing Sound Always Come From Right Chanel Of Speaker
Also No Effect By Switching The Ports in ALC 892
The Sound Get Reduced When I Uninstall Realtech Driver and Use The Default Windows one but only 70 % and It Changes Pattern when Changing This
29-03-2012, 10:49 PM
#28 (permalink)
Today I Dissembled My PC even Till The Heat Sink and Thermal Compound and Replaced It To New Then Tested It On A Test Bench and The Sound Was Still There .....
It is Now Continuous but momentary sound and Irritates me a lot ...
Got The Whole Set Up Assembled and No Luck The Sound Was There
I Have A OLD Power SURGE and don't Know About Its Grounding Status ...Could it Be The Problem
Any One You Guys Have ALC 892 or MSI Motherboard and Had Same Problem ????
29-03-2012, 11:14 PM
#29 (permalink)
change 192000Hz studio quality to 48000Hz studio quality.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
29-03-2012, 11:20 PM
#30 (permalink)
Tried That Audio Is Most Stable Then
I Think I Have Dual Driver Problem See This
And Also How To Increase The Gain Out Put Volume Of My Gaming Headset The Have Low volume when Directly Connected To PC but High When I Connect to TV Etc
