Old 13-09-2011, 10:16 PM   #1 (permalink)
Default PC freezing randomly
Hey guys
Sorry if I m posting this question in wrong section.
My problem is that my pc is freezing randomly & then I have to reset it. After that it works fine. This is happening for the last two days.
I have four OS on my pc but this problem is occuring mainly in windows 7. So please help.
ARJOT SINGH is offline   Reply With Quote
Old 14-09-2011, 08:30 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: PC freezing randomly
specs full config please
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 14-09-2011, 06:58 PM   #3 (permalink)
My config is
Intel core2duo e4500 @ 2.2GHz
Asus P5GC-MX motherboard
2 GB ddr2 ram
HDD - 500GB WD green & 320GB Blue
Zotac Geforce 9400gt 1GB
OS :- Win xp pro sp3, Win vista ultimate sp2, Win 7 ultimate sp1, Linux mint 10
Old 14-09-2011, 07:56 PM   #4 (permalink)
iGoogle
guru_urug's Avatar
check ur cpu temperature using a software like speedfan, cpu-id, speccy,etc and post the values here. Also mention which psu u are using
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
guru_urug is offline   Reply With Quote
Old 15-09-2011, 04:03 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Are you facing the porb in all OSes or in win 7 only ??
Check your ram modules with a app named memtest.
ToPsPeEeD = FaSt BuT StEaDy
Old 15-09-2011, 07:45 AM   #6 (permalink)
mithun_mrg's Avatar
if its happening only in windows 7 boot into safemode in win7 & see if it hangs there
Old 15-09-2011, 07:02 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
try resetting your bios at least for one instant.
d6bmg is offline   Reply With Quote
Old 17-09-2011, 09:24 AM   #8 (permalink)
1. Get the latest bios update.
2. Check using a diff memory stick. Get a memory stick of some good co. like Transcend, Zion, OCz etc.
3. Try using a SMPS of a reputed make.
4. Install the Latest drivers. You can download them from the respective m/b manufacturer's site.
5. Change your source CD/DVD of Windows 7.
ranadive is offline   Reply With Quote
