12-09-2011, 03:25 PM
Cost of Running a PC 24x7
Well, this has been a question for some and so its for me too? How much does it cost for running a PC in Indian House holds?
Ok, i exaggerated by saying 24x7 but will be running my PC for 15 hours daily, how much of power consumption would it take?
I run a 450W power supply, I use it for browsing, some application not Power hungry and certainly No GAMES at all
So can anyone give any idea? please do not post complex tips from other websites and all, I want user experience, how many run PC full time, What is approx electricity Bill?
Processor- AMD X4 635
Monitor- BenQ 22 inch LCD
Ram- 2GB (standard quality ram)
PSU- 450W
MB- Asus Standard
Is this enough to pin point Electricity usage?
12-09-2011, 05:13 PM
Gamer
Re: Cost of Running a PC 24x7
Electricity bill will increase 20-30%...
I run my computer 15-18 hours a day almost everyday with a usage habit similar to yours, but it's not possible to cite an accurate figure for energy consumption without a dedicated power meter. It is possible to make an educated guess - an approximate figure based on estimated power consumption, but you'll have to give your configuration including the monitor.
12-09-2011, 05:57 PM
Depends upon the config of the PC & application run u have to find out exactly how much watt it consumes
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
12-09-2011, 06:59 PM
@pimpom Do you know the Difference between when you started using your PC and When you didn't have the PC at home?
12-09-2011, 07:15 PM
Not really possible to say. I've been using computers for a long time and during that time, there have been many other changes in the way we use power in my home.
Just state your config and I or someone else can give you an estimate of the extra energy consumed by your computer. From your usage habits, it may be a low-end system, but we still need details.
12-09-2011, 08:54 PM
iDota
My PC has added some 200 to 300 bucks to the monthly bill is all I know.
12-09-2011, 09:35 PM
I did post config, see first post.
What is your config? High End?
12-09-2011, 10:13 PM
OK, but you added that several hours after the first post and I didn't check the top part of the thread when I refreshed the page since you didn't mention it in later posts.
You still didn't mention the HDD, optical drive, whether you have a discrete gfx card, etc. Let's assume that you're using one conventional HDD (not SSD), one optical drive, an IGP, no expansion card and no external drive, low power speakers (if any), one modem and that the monitor is CCFL, not LED, and also that you rarely use a printer. Even the PSU model makes a difference because cheap PSUs waste more power.
Based on those assumptions and your usage habits, my estimate is that your computer consumes roughly 40-65 units (kWh) a month. If the energy rate is, say Rs.3 per unit in your area, that would come to Rs.120-200 per month.
13-09-2011, 08:23 AM
Yes your right about rest of my config! that is why i didn't mention any GFX card too!!
13-09-2011, 07:04 PM
BMG ftw!!
Power consumption: 400X15X30/1000 = 180 kWh/month. (assuming that your PC consumes 400W.)
Now add price per unit to get correct result.
13-09-2011, 07:29 PM
Adam young
^^where to add the price per unit?
i don't have any i dea how these monthly charges are calculated.
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
13-09-2011, 08:00 PM
iGoogle
Read this article on Toms Hardware.
Picking The Right Power Supply: What You Should Know : Brought To You By Granny’s Radio
It explains the working of ur PSU and how it consumes power. The graph is definitely not linear...or even standard. To know ur power consumption u wud need a dedicated power meter. No formula is gonna give u proper approximate values, cause every PC component is different,so are the usage scenarios etc.
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
13-09-2011, 09:38 PM
I made some assumptions too in giving my own estimate above because it's impossible to know the exact amount without actually measuring the OP's consumption with an energy meter. However, I think 400W is way too high. Power consumption is often over-estimated because many people think in terms of the maximum ratings of the PSU.
The OP's rig does not include a discrete gfx card or other add-ons and with his usage habits, the system will be running at almost idle power most of the time. So I based my estimate on an average consumption of roughly 100-150W.
The OP didn't even want to know how the calculations are done, so I just gave an estimate of the energy unit consumed per month. The only calculation that had to be brought up was that of converting the operating cost from energy units to money. That's because I don't know what the rates are in his area.
Look at your electricity bill. The rates are probably printed there.
14-09-2011, 06:50 PM
BMG ftw!!
multiply price per unit with the wattage measures in KWh.
14-09-2011, 10:02 PM
Blender Artist
@ robbinghood
in our home the energy meter calculated the power as KWPH (Kilo Watts Per Hour)
Which means 1000W = 1 Unit
in your case if your Pc consume 400W per hour means, it took 2hrs 30minutes to consume 1000W.
So if you use you Pc for 2hours 30 minutes it consume 1 unit of electricity bill.
if you use your pc 15 hours daily means 400 (watts) x 15 hours = 6000 watts totally in 15hours your pc consumes 6000watts is equal to 6 unit.
now 6Unit x 30 days = 180units your pc consume per month.
27-09-2011, 12:12 AM
i had read sumwer dat it take 9-10units if u run ur pc 24hrs with monitor kept on
PS: sum ppl keep der monitor off n keep pc on for downloading d stuff frm net
AMD X6 1055T, Gigabyte 880GM-USB3, Corsair 4GB DDR3 XMS3 1600MHzNZXT, NZXT Gamma,Corsair VX450W, Zotac GT 430 1GB DDR3,WD Caviar Green 640GB HDD, Samsung 2033 Sync Master,500GB WD Portable HDD
27-09-2011, 11:46 PM
BLUE IS THE COLOUR
400W ?? Its the specification of PSU, no home PC's will consume that much power.My PC takes only 117W when in Idle and 260W in load (gaming).I monitor that in APC powerchute software.My guess would be an average 100W x 15hrs for his PC.So 1.5 units per day and 45units per month.So the bill would be around 135/- if the price per unit is taken as 3/-
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
