Digit Technology Discussion Forum
Hardware
Hardware Q&A
Please help....No display
User Name
Remember Me?
Password
Register
FAQ
Calendar
Mark Forums Read
Hardware Q&A
Discuss basic Hardware problems, find solutions to your hardware queries which don't fit in the other sections.
LinkBack
12-09-2011, 01:05 PM
1
permalink
bajaj151
While working....system hangs.
I press RESTART button.....after that NO display. All fans working (incl. CPU)
Already done
1) Reseat CPU
2) Clean RAM (checked 1 by 1)
3) Monitor working fine on other PC
4) With & Without CMOS Battery
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard |
Sapphire 7850 OC
12-09-2011, 02:24 PM
2
permalink
khmadhu
change is constant!!
Re: Please help....No display
be more specific.. specify which application u use..?
if it hangs while using any graphics app..? check for graphics drivers.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
12-09-2011, 02:34 PM
3
permalink
bajaj151
No graphics application...it was idle...
Other thing
1) Power & HDD LED also not working..
2) After removing both rams...No beep
Sapphire 7850 OC
02:40 PM
13-09-2011, 11:53 AM
4
permalink
Sara757
Hi, Try to check with some other monitor if it is working fine than check the resolution of your system or if wire is connected properly or not.
13-09-2011, 03:02 PM
5
permalink
bajaj151
Motherboard sent to SMC for replacement.....
How long it takes for a replacement ?
Sapphire 7850 OC
13-09-2011, 03:11 PM
6
permalink
khmadhu
typically 10 to 15 days...
Digg
del.icio.us
StumbleUpon
Google
Previous Thread
Next Thread
Show Printable Version
Email this Page
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
Forum Rules
can't find the bug
- by
amrutansu garanaik
Battlefield 3 discussion!
- by
cyborg47
Battlefield 3 Multiplayer Discussion
- by
Charan
New gaming cafe in mumbai...need help
- by
nikimation
Diablo III Discussion
- by
Gaurav Bhattacharjee
Letsbuy.com now integrated with Flipkart.com
- by
Terabyte
the FOOTBALL channel
- by
Arsenal_Gunners
The Offtopic discussion thread...
- by
IronManForever
Kingdom of Amalur: Reckoning discussion
- by
vamsi_krishna
Must Watch Movies in High-Definition
- by
trublu
01:19 PM
Contact Us
Thinkdigit.com
Archive
Top
LinkBack
LinkBack URL
About LinkBacks
Search Engine Optimization by
vBSEO
3.3.2
