Old 10-09-2011, 02:54 PM   #1 (permalink)
Post Front Audio ???????
hi guy i got a bijli cabinet yesterday and i connected the audio pin for the front panel to the motherboard but it does not detect the earphones
???? why is that ?????
Tarun is offline   Reply With Quote
Old 10-09-2011, 05:58 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Front Audio ???????
did u connect the internal connectors properly on MB also up date the sound drivers
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 11-09-2011, 12:11 AM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
While connecting front panel connectors to pins, see the manual of motherboard for details. Most probably you have connected in a wrong way.
d6bmg is offline   Reply With Quote
Old 11-09-2011, 01:48 AM   #4 (permalink)
na i checked the thing many times its perfectly set as it should be
Old 11-09-2011, 03:12 AM   #5 (permalink)
BMG ftw!!
d6bmg's Avatar
did you disabled front audio option in your bios settings?
Old 11-09-2011, 02:51 PM   #6 (permalink)
Na i cant find the option in the BIOS
Old 11-09-2011, 04:45 PM   #7 (permalink)
Adam young
sukesh1090's Avatar
^^same problem i am facing in my gigabyte mobo.usb works but no audio.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 12-09-2011, 12:20 AM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
BIOS reset or updating bios to its latest version may just work.
Old 12-09-2011, 07:05 AM   #9 (permalink)
^^it is already updated no use i think have ot update my drivers
Old 12-09-2011, 07:11 AM   #10 (permalink)
mithun_mrg's Avatar
also in the bios shuffle the front panel audio option to HD/ac97 & see generally it is located in intregrated peripherals
