^^ Its a good point mentioned by you. I heard people coming back to shop from which they have purchased USB3.0 HDDs complaining that they are not getting fast data transfer speed and in those cases they don't even have USB3.0 ports in their mobos.
Both of them are good HDD but WD one comes up with USB 3.0.And for future purpose its added advantage(Considering your friend don't have USB 3.0 port in his pc)The copy speed also twice-thrice as fast than USB 2.0.
Agreed. But Seagate has a feature that allows you to plug any 2.5" generic HDD to your PC via this dock.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
@ Tenida
Friend, my pal does not have USB 3.0 ports on his computer.
Also, he is reluctant on the WD drive especially after knowing my portable drive developed a problem. He is very finicky about such issues.
@ Ishu Gupta
Friend, could you please explain your last post? I am sorry, i did not understand.
let us all see the "i" in the "u".
I had called the Seagate technical support in the not so distant past to clarify warranty periods.
The customer service agent informed that Seagate had reduced the warranty period from 5 years to 3 years on products purchased after a certain month & year which for some reason, i cannot recollect.
Customers who have purchased Seagate products before the time period which i cannot remember, have & can avail the 5 year warranty.
Please call the Seagate toll free number - 1800 425 4535
& clarify for your sanity!
I may be wrong about the aforementioned claims.
Reason: grammatical error!
Seagate Freeagent both portable and desk version-5 years warranty
Seagate Goflex Desk-3 years warranty don't know portable version.
I have Freeagent portable bought 1.5 years ago. It says it have 5 years of warranty.
Originally Posted by insaneYLN
The customer service agent informed that Seagate had reduced the warranty period from 5 years to 3 years on products purchased after a certain month & year which i for some reason, recollect.
@Ishu Gupta: the pic @ post#15 show a sata connector with a usb connector on other end...& below is the image of normal SATA 3.5" HDD...
where is the power port of the converter...so that it can be used with 3.5" HDD??
The long L shape is the power connector and the smaller L shape is the sata connector.
You need the external power GoFlex or the USB3 one if you want to connect 3.5" HDDs.
