Old 10-09-2011, 10:23 AM   #1 (permalink)
Default System Stuck Sometimes at BIOS
Hey guys,
I have this problem with my 2 year old PC. Thing is, sometimes when I boot up, the system gets stuck at the BIOS screen. The problem goes away when a turn it off and on again, but sometimes it doesn't. Another thing I've tried is re-inserting the RAM sticks, in different slots, or switching the slots of the RAM sticks. Then, it works fine. But after a few days, it starts again. But, I've noticed no effects on performance as after I log in, I can play Crysis 2 or Dirt 3 at a stretch for around 4-5 hours. Benchmark scores are also not affected. Here's my config: Intel E8400 @ 3.0 Ghz
Zotac GTX 260
WD Green 320 GB (Not sure about specific model)
Kingston 2x2 GB DDR-2 800 RAM
500 W Cooler Master Exteme SMPS
Intel DG35EC Motherboard
Win XP Professional 32 bit
Win 7 Ultimate (Dual Boot)
Thanks In Advance!
Drumminggeek is offline   Reply With Quote
Old 10-09-2011, 12:08 PM   #2 (permalink)
Default Re: System Stuck Sometimes at BIOS
^^ when system gets stuck at bios screen, is the hard drive listed immediately or after a few seconds. & also once it gets stuck, can you enter the bios screen (the settings page?).
Old 12-09-2011, 05:16 PM   #3 (permalink)
is it 1TB hdd?
prudhivisekhar is offline   Reply With Quote
Old 12-09-2011, 05:54 PM   #4 (permalink)
mithun_mrg's Avatar
I have seen many Intel MB having this problem update the bios
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 17-09-2011, 04:57 PM   #5 (permalink)
Yes but 1-2 minutes after hittin' f2.
Old 17-09-2011, 05:03 PM   #6 (permalink)
Not exactly... after I hit the f2 key.... it takes about 1-2 minutes to respond
Old 18-09-2011, 04:10 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - do you have the latest bios version installed for the mobo - if not update the mobo bios to the latest version.
Other two things you can try resetting the CMOS setting and Change the CMOS battery.
ToPsPeEeD = FaSt BuT StEaDy
Old 18-09-2011, 12:34 PM   #8 (permalink)
yep latest bios is already there....any specific model for the battery ?
Old 18-09-2011, 01:31 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ battery model should be same as existing one.
d6bmg is offline   Reply With Quote
Old 19-09-2011, 04:23 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
@ Drumminggeek - if you are unsure what battery to buy just take out the current CMOS battery from the mobo and buy a matching one from any computer hardware shop.
BTW, IF possible Check your ram modules with memtest app and your HDD with HDTune.
Old 19-09-2011, 07:08 AM   #11 (permalink)
mithun_mrg's Avatar
i think if he purchases from a computer shop it will be fine
Old 19-09-2011, 08:26 AM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
Those battery are big Button cells which we use on digital clocks ,cr2048 I think, they are available at watch repair shops, fancy stores...
Edit: I think its Cr 2032.
Take the Battery out of the motherboard and check.
ASUS K53SV SX520D + BF3
s18000rpm is online now   Reply With Quote
