09-09-2011, 08:11 PM
3HDDs on local 450W SMPS ? 19A on +12V
i bought 1TB WD caviar green today. but i am worried if its safe to install it as i have already installed 2 HDDs on my local smps. complete PC specs are :
CPU : pentium dual core E5300 2.6GHz [running @ stock speed]
RAM : 4GB DDR2 800MHz
GPU : sparkle GT240 1GB DDR3 [stock speed]
HDDs : 250GB WD caviar blue and 500GB hitachi
ODD : LG burner
mobo : ASUS P5KPL-AM/PS
2X 80mm LED fans [i keep them off during winter]
1X 92mm fan [chassis fan]
PCI based USB card
SMPS : Hytech 450W with 19A on +12V rail.
i had OCed CPU to 3.4GHz and GPU to 630Mhz [from 550Mhz] when i used to play GTA4 and it was running fine.
should i install the new HDD
WD caviar green needs 0.55A on +12V.
i dont want to buy new SMPS
09-09-2011, 08:39 PM
Gamer
Re: 3HDDs on local 450W SMPS ? 19A on +12V
Your PSU will handle that easily but it is suggested that you upgrade to VX450 PSU from Corsair.
09-09-2011, 08:51 PM
Dont worry it will work fine, But yes keep the OC in check. If possible reduce GPU Clock. Will strain the local PSU less.
Although I reccomend to completely remove the Overclock as its only a Local PSU
If you can spend around Rs.2000, get a FSP Saga II 500w. Great VFM PSU.
But yes if you add this HDD Remove atleast one OC.
09-09-2011, 10:28 PM
i have not OCed anything this time. i will never OC when i install 3rd HDD and i will remove LED fans too. is it safe to install that HDD??
i will upgrade my PC next year and i dont want to buy new PSU before that
10-09-2011, 03:23 AM
Fast 'N' Furious
I would recommend you to run your cpu and gpu at stock speeds for now with the new HDD just to be play safe
10-09-2011, 07:21 AM
@op if u even buy a good psu now u can use it with the upgraded system
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
10-09-2011, 12:07 PM
hard drive are not as power hungry as the other parts. safe.
10-09-2011, 01:19 PM
Adam young
+1 for mithun_mrg.if you buy a good psu now,you can also use it with your future rig.
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
10-09-2011, 01:36 PM
Yes. Its safe. Local psu might (most probably will) spring a surspire he pushed too hard.
10-09-2011, 08:17 PM
thxx..
@mithun_mrg : No one sells branded PSU here  only odyssey, zebronics, hytech, intex ****.. i will order new 600W CM/tagan next year when i will upgrade. i dont really want to spend my pocket money in new smps this time
10-09-2011, 08:46 PM
Well, for 600w PSU you should really get Corsair GS600.
Best of luck.
11-09-2011, 12:07 AM
BMG ftw!!
Don't go with CM 600W.
Either opt for Corsair GS600 or opt for Corsair CX 600W V2.
11-09-2011, 04:00 AM
Fast 'N' Furious
There's no point in getting CX 600v2 when one can get GS600 by paying only 200 bucks more
11-09-2011, 11:45 AM
BMG ftw!!
^^ Ok, edited my post.
12-09-2011, 07:03 AM
thxx..
in my place also no one sells branded psu  get it online from primeabgb or smc international as others have already said avoid CM
