im using above model laptop....its having nvidia geforce 8400 gs graphics card....i had installed fedora 15 and nvidia driver....when i view the temperature of the display card from nvidia menu its rising from 45 degree to 55 degree celciuse......does every card temp vary like this or this is a problem......i recently
changed the graphics card spending lot of money.......hope you reply soon.....
its normal temperature for a laptop gfx card.so nothing to worry as notebook parts get heated up a lot and also capable of withstanding high temperatures.
OK. I thought you were talking about the MSI external GPU thing. MSI said that the express slot bottlenecks (or was it due to power connector?) anything above a HD5670 (similar to HD6770M).
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
