Old 08-09-2011, 03:42 PM   #1 (permalink)
bajaj151's Avatar
Default Sony Vaio Temperature Check...
Laptop: Sony Vaio VPCEB14EN
Purchase Month: August 2010
Use: Internet + Music + Movies....NO GAMING
Warranty: Expired
Idle temperature : 55-60 degree (using CoreTemp 64)
Query: Why may be the reason of high temperature ?
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline   Reply With Quote
Old 08-09-2011, 04:03 PM   #2 (permalink)
Default Re: Sony Vaio Temperature Check...
Well, this seems not very high.Quite Normal. Laptop components are meant to handle even 80c or above.
After how much time of use is this Temp?
Old 08-09-2011, 04:03 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Those are fine.
asingh is online now   Reply With Quote
Old 08-09-2011, 04:11 PM   #4 (permalink)
bajaj151's Avatar
30-40min...
Old 09-09-2011, 01:07 AM   #5 (permalink)
BMG ftw!!
d6bmg's Avatar
May be its due to accumulation of dust in cooling fan of laptop or problem with cooling compound.
d6bmg is offline   Reply With Quote
Old 12-09-2011, 05:15 PM   #6 (permalink)
go to service centre and get the heat-sink and the cooling fan of your laptop cleaned.
prudhivisekhar is offline   Reply With Quote
Old 13-09-2011, 09:28 AM   #7 (permalink)
No. 55-60 ARE PERFECTLY SAFE AND NORMAL in laptops.
Laptops dont have ample space. They have compact space and limited cooling options.
Laptop components are able to withstand 100c even. So if you cross 80c in 30-40 mins in normal usage, it would be matter of concern.
55-60 is normal even in desktops.
