Old 05-09-2011, 10:48 PM   #1 (permalink)
heartripple's Avatar
Default Computer is not turning on beep code error
I have given my old rig to my friend and it is as shown below
AMD Athlon 4200+
Asus M2NMX
Sony DVD writer
Zion 800 Mhz 2GB RAM
Seagate 80 GB HDD
For past few days he is facing a problem> When he tries to turn on the pc one long and followed by two short beep continues that cycle.....and nothing happens after that
I have disconnected all the parts one by one ....after that removed the battery and inserted it again ...problem solved for two days and then reappeared ...
Now suggest me the permanent solution...
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout ||
Nokia N-8, Sony Ericsson C905 both rocks my world...
heartripple is offline   Reply With Quote
Old 06-09-2011, 05:11 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Computer is not turning on beep code error
check the rams using memtest.
ToPsPeEeD = FaSt BuT StEaDy
Old 06-09-2011, 07:55 AM   #3 (permalink)
mithun_mrg's Avatar
also check with a discrete video card
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 06-09-2011, 09:13 AM   #4 (permalink)
will try both of this and then let you know what happened....
Old 07-09-2011, 03:42 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
looking at the config posted on the first post - I think his friend is using the mobos onboard IGP
Old 07-09-2011, 07:10 AM   #6 (permalink)
mithun_mrg's Avatar
^^ yep thats why i told him one long & 2 short in ami bios generally means gpu/Vram error
Old 07-09-2011, 12:14 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Problem with ram modules.
d6bmg is offline   Reply With Quote
