Old 05-09-2011, 05:23 PM   #1 (permalink)
Arrow Gaming Cabinet with USB 3.0
Require a decent gaming cabinet with proper airflow and cooling and which supports USB 3.0 and can accomodate MSI HD R6950 2GB Twin Frozr III GPU comfortably.
priyam1309 is offline   Reply With Quote
Old 05-09-2011, 06:10 PM   #2 (permalink)
iDota
Sarath's Avatar
Default Re: Gaming Cabinet with USB 3.0
^ State your budget first
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 05-09-2011, 06:29 PM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
HAF 912 Advanced, CM storm etc and thousands of other cabinets.
But above all post your budget.
d6bmg is offline   Reply With Quote
Old 05-09-2011, 06:58 PM   #4 (permalink)
Exclamation Re: Gaming Cabinet with USB 3.0
I have no idea. The lower the better. Maybe around 4K - 5K. But of decent quality. I saw Cooler Master Storm Enforcer Mid Tower ATX for $89 but could find indian price.
Old 05-09-2011, 10:02 PM   #5 (permalink)
BMG ftw!!
d6bmg's Avatar
Cooler Master Storm Enforcer is avilible at Indian market @5.4K
Old 05-09-2011, 10:46 PM   #6 (permalink)
iDota
Sarath's Avatar
Thats a nice case. I own this one and its pretty good. NZXT Tempest Evo w/ 6 fans
Old 05-09-2011, 10:48 PM   #7 (permalink)
Manchester United <3
Ishu Gupta's Avatar
+1
Has front USB3.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 05-09-2011, 11:01 PM   #8 (permalink)
At what price you bought this cabinet? Also, how the fans that come bundled with the cabinet performs, do they make noise?
Actually looking forward to buy this cabinet........
digyourpc is offline   Reply With Quote
Old 06-09-2011, 12:59 AM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ Then you may also like Corsair 700D. Or at extreme budget of 15K, Corsair's black pearl, 800D Full tower.
AFAIK, NZXT Tempest Evo doesn't have any front USB3.0 ports.
Old 06-09-2011, 05:23 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Fans :
FRONT, 2 X 120 mm Blue LED (included)
REAR, 1 X 120 mm (included)
SIDE PANEL, 1 X 120mm Blue LED (included)
TOP, 2 X 140mm Fan (included)
the fans are of 1000RPM and is noiseless AFAIK and price should be around 5.7k - if you can live with usb 2.0 front panel connectors then it's a great cabby to have
ToPsPeEeD = FaSt BuT StEaDy
Old 06-09-2011, 10:30 PM   #11 (permalink)
iDota
Sarath's Avatar
^Yeah everythings laid out above.
However my room is extremely silent and I cant help but notice the fans since there are 6 of them. But that might be due to my setup where the CPU sits to my right.
