Old 04-09-2011, 09:39 AM   #1 (permalink)
Smile Does MTS MBlaze work on 64bit Win 7?
Hello Guys,
Recently I am planning to get a Mts Mblaze connection. But I am skeptic about the fact that if it works on 64bit Windows 7 Home Premium. Have you guys tried the same? Does it work without glitches?
And Thanks for helping.
Jeet is offline   Reply With Quote
Old 04-09-2011, 11:10 AM   #2 (permalink)
aniket.cain's Avatar
Default Re: Does MTS MBlaze work on 64bit Win 7?
Yes it works. I am using it on Windows 7 Ultimate 64bit. I was using Win 7 Home Premium 64bit before this, and it worked fine on that too. So, no problem there.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 04-09-2011, 11:19 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@Jeet: the MTS device has both the windows drivers x86 & x64 so no worries
Old 04-09-2011, 12:33 PM   #4 (permalink)
Thanks Guys. Just another small question, should I install the installer that comes inside the modem, or should I download the driver presented on the right side of the mts India website? Are they both same or they are different?
Old 04-09-2011, 07:27 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
the drivers u get with modem may be old..so updating from their official website is always recommended
Old 04-09-2011, 07:33 PM   #6 (permalink)
Thanks ! Problem Solved
