Old 03-09-2011, 09:43 PM   #1 (permalink)
Racing 24X7
NitrousNavneet's Avatar
Default Widescreen Monitor
wHY WE NEED A WIDESCREEN mONITOR.
wHAT ARE IT's Properties ?
I mean
I watched Ready in My new widescreen Moni. and Salmaan and Aseen were very Nataa & motaa on the screen.
Is there any cure of it?
"Those Who Are Afraid OF Falling Will Never BE Able To Fly"
>>Intel dual core 2.20 GHz
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
>>Asus Eah4350 Silent Graphics Card
>>Windows 7 ultimate X64
Please
Help
NitrousNavneet is offline   Reply With Quote
Old 03-09-2011, 11:13 PM   #2 (permalink)
Default Re: Widescreen Monitor
If this is a serious post and if I interpreted the somewhat gibberish question correctly, you have to change your display settings to match your monitor's resolution.
Did you start using an LCD monitor recently? What is the model number? What is your display setting?
pimpom is offline   Reply With Quote
Old 03-09-2011, 11:54 PM   #3 (permalink)
mithun_mrg's Avatar
@op dvd or blue ray resolution is ment fo the widescreen disp i.e 16:9 get the movie on above media it will be ok whereas vcd has 4:3 resolution so when u switch to fullscreen the picture is streched that is the cause of ur problem
Sent from my GT-I5510 using Tapatalk
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 04-09-2011, 07:35 AM   #4 (permalink)
Racing 24X7
I am using Acer H163HQ.
Yes It is my 1st WS moni.
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 04-09-2011, 08:46 AM   #5 (permalink)
The Warchief
Kola2842's Avatar
^^Your problem is due to low resolution of your movie, not of monitor.
If you set that to fullscreen , it'll get streched and gives you "nata-mota" experience.
Either get hd quality movie or play it in native resolution of dvd.
No need to insult/curse a Widescreen
also check following, if you have lowered you display below your monitor resolution.
Originally Posted by pimpom
you
resolution.
Kola2842 is offline   Reply With Quote
Old 04-09-2011, 01:23 PM   #6 (permalink)
Your monitor's native resolution is 1366x768. Set your display settings to that resolution.
If you still have a problem showing movies in the correct aspect ratio, it may have something to do with the codecs you have installed.
Old 06-09-2011, 04:49 PM   #7 (permalink)
Racing 24X7
HOW ?
I have to option
A) 1020 X 768 ( Already using it)
B) 1152 X 864
IN option B) the contents are going aut of the screen ( I have to scroll Down . even on desktop).
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 06-09-2011, 04:57 PM   #8 (permalink)
mithun_mrg's Avatar
@op then reinstall ur Gpu drivers
Old 06-09-2011, 05:52 PM   #9 (permalink)
Adam young
sukesh1090's Avatar
yes reinstall your GPU drivers.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 06-09-2011, 07:44 PM   #10 (permalink)
As others have said, reinstall your display driver. If that still doesn't work, it may be because your driver is too old and doesn't include the 1366x768 setting. You can download the latest driver here
Old 11-09-2011, 08:43 AM   #11 (permalink)
Racing 24X7
Will It work on my Eah 4350 1gb graphics card?
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 11-09-2011, 11:28 AM   #12 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ Yes, it will.
P.S. I laughed hard while reading the first post of this thread.
d6bmg is offline   Reply With Quote
Old 11-09-2011, 12:15 PM   #13 (permalink)
the link is for AMD Catalyst drivers. will work for any AMD GPU from HD2*** & also for similar IGP. install these & in the display properties a new resolution should be listed: 1366×768.
Old 12-09-2011, 12:00 PM   #14 (permalink)
Racing 24X7
Done
but now my other Photographs are lamba patlaa.
Are there any soft. to manage the Resolution automatically as picture's reso. ?
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 12-09-2011, 01:12 PM   #15 (permalink)
aniket.cain's Avatar
Windows itself adjusts the images and all on-screen contents to match the resolution of your monitor. Seems you haven't set your resolution to the native resolution of your monitor, which is 1366x768. If you have set to this resolution, then everything should definitely look fine.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
