Old 31-08-2011, 07:12 PM   #1 (permalink)
The Witcher
Maddd's Avatar
Question Upgrading help.
Hi !
I play resident evil 5 on my pc. But it gives low fps so i have to lower graphic at 800x600.
I want to upgrade ram. Tell me will 2gb do the job.
System config:
core2 duo 2.93 GHz
asus p5km-ps
512 MB 8400gs
1 gb ram
Maddd is offline   Reply With Quote
Old 31-08-2011, 08:04 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: Upgrading help.
^^buddy you have to upgrade your graphics card along with your RAM to get better FPS.only upgrading the ram won't do the job.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 31-08-2011, 09:13 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
Agreed with sukesh. Mention your budget and your PSU so that we can suggest appropriately.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 01-09-2011, 12:38 AM   #4 (permalink)
The Witcher
Maddd's Avatar
Ok thanks for reply.
Now i have 5000 RS.
And bad thing is that i have stock psu 450w
Old 01-09-2011, 01:10 AM   #5 (permalink)
The Assassin
Cybertonic's Avatar
Get HD5670 512mb for 4k and if possible FSP saga ii 350W at 1.4k too.
Steam : $/@$]-[ DK
Old 01-09-2011, 08:14 AM   #6 (permalink)
The Witcher
Maddd's Avatar
So i need more money. Ok i'll manage and reply soon.
And tell me
1. if 350w psu is suffice?
2.What os is better for my system? Win XP OR WIN 7 in terms of gaming.
Old 01-09-2011, 09:37 AM   #7 (permalink)
Adam young
sukesh1090's Avatar
^if you are going to stick with that 1GB RAM then XP.if you are upgrading then windows 7 is the best OS without any doubts.
-Rifleman's Creed
