Old 31-08-2011, 03:18 PM   #1 (permalink)
Default The donkey rig...,
hello guys, i want to setup a donkey rig - not in dumb sense, more like a hard working one. I do not want a high end pc, a medium range that could work of hours without dying soon due extreme temperatures etc, it should solve the following purposes:
1)downloading data for hours at a stretch.., sometimes i leave my pc without shutdown for 24-30hrs.
2)should be able to play all 1080p files without hassle even the large 10gb rips.
3)do basic gaming like nfs-mostwanted, CODMW games. (i dont want to spend much since i already have a gaming console).
4)run photoshop and other apps smoothly (my work vil not be heavy as am a beginner).
5)no driver issues for windows 7 ulti.
6)usb3.0 support. multiple usb ports.
8)encode/convert 'hd' stuff for my portable media devices.
7)heavy internet usage. with10mbps internet i feel like the world is mine!!
now already have a 19" lcd monitor, and an amd phenom quad 9550 2.3ghz procy, 4gb ram sticks,keyboard and mouse combos, an a big cabinet! No PSU though. i will ditch the procy and ram for new ones if necessary.
please suggest me the other components, with the cheap and best config thats possible, to create a perfect personal donkey computer
i understand prices may vary with place etc but i can adjust for that.
thnx guys.
proud DIGITIAN, (level 10/100)
ps: i fried one motherboard, and another is on its way to the grave, so please suggest me something which would last atleast 3yrs.
TEMPLATE:
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: play, encode/convert 1080p files, nfsmw,codmw, run ps, heavy downloading, system needs to run nonstop and shouldn't fry up!
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: yes
3. What is your MAX budget?
A: motherboard+graphics solution(10k), AM+2 socket, already have a phenom quad 9550 2.3ghz (should a ditch this?) -if new procy -6k, appropriate cooling system.
4. Planning to overclock?
A: no
A: win7 ultimate primary, dual booting linux or vm.
A: none - i have plenty.
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: 1440x900 19" samsung monitor -am using it.
A: 6
A: no, but, i can assemble it myself -thanks to digit
A: asap
A: 2-3yrs would suffice,
A: no pci cards for now.
A: hyderabad, yes i am open to buy from other shops and online if feasible.
A: should withstand long hours of running without frying up.
bhadkow is offline   Reply With Quote
Old 31-08-2011, 03:30 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: The donkey rig...,
don't forget to mention the important part "Budget"
Old 31-08-2011, 08:18 PM   #3 (permalink)
Adam young
sukesh1090's Avatar
Mention your Budget.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 31-08-2011, 09:44 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
Please fill up http://www.thinkdigit.com/forum/pc-c...-template.html so that anyone from here can suggest you a proper config.
d6bmg is offline   Reply With Quote
Old 04-09-2011, 02:50 AM   #5 (permalink)
b.u.m.p
Old 04-09-2011, 03:41 AM   #6 (permalink)
aniket.cain's Avatar
You haven't mentioned you budget. How do you suppose people would come up with a rig without it?
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 04-09-2011, 04:02 AM   #7 (permalink)
Manchester United <3
Ishu Gupta's Avatar
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 04-09-2011, 10:17 AM   #8 (permalink)
Jai Suresh
lywyre's Avatar
I guess your processor is already good enough.
MB - Gigabyte MA880GM-USB3L - 5500
GFX - XFX ATI 5570 1GB DDR5 - 4900
You also have to invest in a good PSU. Also, if you RAM sticks are DDR2, you have to replace them with DDR3 (2GB sticks start from 625, Chennai).
Alternatively, you can just throw in a good GFX card and PSU only into your existing config.
lywyre is offline   Reply With Quote
Old 05-09-2011, 03:02 AM   #9 (permalink)
thnx for the reply.., i vil chk it out, and i need to change the board (asus M3N78-VM) as i have minor but annoying issues with audio ports,usb ports. i also suspect the psu might be causing power issues as 3.3v sensor is measuring only 2.8v.
so wat psu rating should i go with and which model? (i suppose i needn't mention the budget for this..) anyways thnx for the help mate
Old 05-09-2011, 07:24 PM   #10 (permalink)
If you dont have to upgrade Gpu, get the FSP Saga II 500w @Rs.2000
Old 05-09-2011, 10:02 PM   #11 (permalink)
BMG ftw!!
d6bmg's Avatar
+1 for fsp saga II. Constraint: thetechfreak's point.
Old 10-09-2011, 01:46 AM   #12 (permalink)
^thnx guys.., i wont be upgrading and will be usinge the one suggested...,
