Old 31-08-2011, 02:15 PM   #1 (permalink)
Gamer
Default PC Wont boot
I thought of cleaning my motherboard and the chassis. I removed all cables, except the cpu, heatsink, gpu and ram. Now when i turn on my pc there is no display and no hdd activity. I have a p5qpl am mobo.
Can u guys plz help md out
ArjunKiller is offline   Reply With Quote
Old 31-08-2011, 02:29 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: PC Wont boot
check all the cables whether they are in place or not.is that the computer starts and HDD is not detected or the comp itself not switching on?
post your PSU.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 31-08-2011, 02:42 PM   #3 (permalink)
Hmmmmm
Tenida's Avatar
Just tight the all cables and vga cable.
Tenida is offline   Reply With Quote
Old 31-08-2011, 03:04 PM   #4 (permalink)
Gamer
ok, i tightened the power and sata cable to the hdd and dvd writer and inserted sata cables in sata 1 and 2 port. Refitted cpu, applied fresh coat of thermal paste. Refitted the gpu too. Connect all atx power supply cables, cleaned ram and refitted. Still when i turn it on, the cpu light turns on, mobo led turns on, monitor shows no signal. Everything was working perfectly this morning. Btw my psu is iball 500w.
Old 31-08-2011, 04:30 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
mayb u have shaken some MB parts while cleaning it. did u apply pressure on MB ??? else try ur frds psu & c if it turns ON [i know no 1 does help in these situation bt still try].
... W H O T ...
ax3 is offline   Reply With Quote
Old 31-08-2011, 04:41 PM   #6 (permalink)
Hmmmmm
Tenida's Avatar
OK.check the ram again..if u hav two ram stick...then install 1stick at a time.Might be ram issue.Also that iball psu might be faulty.
Old 31-08-2011, 09:57 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Do not use GPU at first, try to boot up PC from motherboards integrated graphics.. Let see what happens. Also try to boot up your PC with minimal config.
d6bmg is offline   Reply With Quote
Old 01-09-2011, 03:09 PM   #8 (permalink)
does your psu fan running hen you boot your system
jagdish is offline   Reply With Quote
Old 01-09-2011, 05:49 PM   #9 (permalink)
Make sure the 4-pin CPU power connector is in place. Remove the graphics card and connect the monitor to the onboard display output. While doing this kind of investigation, it's best to disconnect all drives and see if you get the POST display.
pimpom is offline   Reply With Quote
Old 01-09-2011, 11:21 PM   #10 (permalink)
Stuck in Time...
Vyom's Avatar
Check cables coming out from Monitor. Loose power cable or VGA cable does theis sometimes.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
