30-08-2011, 01:44 PM
Adam young
monitor enteres power saving mode immediately after boot
Guys yesterday when i changed my ram latency to 8-8-8-22 restarted the
System but after restart the monitor shows power saving mode nothing else.it happened even before once but that time it worked correctly after 2-3 restart.i checked monitor with other system and it is working fine.i removed gfx and booted with onboard but still no luck.i inserted ram in another slot and reinserted cmos battery after some time but in vain.system starts perfectly but doen't give any beep.the processor,mobo,ram,hdd are just 1 Week old.so guys what say which is the culprit mobo or psu?
Thank you.
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
30-08-2011, 01:53 PM
Rubik's Uncle!!
Re: monitor enteres power saving mode immediately after boot
Do you get the boot screen or does it enter the power saving mode after booting to windows?
reset/clear the bios.there would be a jumper for that. check you motherboard manual for the location of the jumper. removing the cmos battery may not clear the cmos. also please state your motherboard model.
30-08-2011, 05:02 PM
Adam young
It comes before the bios.the system starts with power saving mode.cpu starts and monitor shows power saving mode.
-Rifleman's Creed
30-08-2011, 05:43 PM
Rubik's Uncle!!
ok clear the bios using the jumper/button based on your motherboard,that should reset the memory timing. other than this I dont see any problem. Also check if you have plugged in the 4 pin aux power for the motherboard.
30-08-2011, 08:13 PM
Adam young
thank you for your support brother.i was able to get my system back in working.btw my BIOS shows DRAM voltage as 1.6V and also hwmonitor and hwinfo shows the same thing but my mobo specs says it only supports up to 1.5V and cpuz shows the same thing.so i believe more BIOS so i consider it as 1.6V.i also checked the dram voltage changing option but it only support increasing the volt not decreasing.so is there any problem when it is using more volt which mobo doesn't support.
-Rifleman's Creed
30-08-2011, 10:27 PM
BMG ftw!!
^^ Congrats buddy. It looks like your ram can't run with 8-8-8-22.
30-08-2011, 10:58 PM
Rubik's Uncle!!
I'm Glad that your system is back online  Im not into tweaking/overclocking the memory/CPU .. so i can't help you in that case. Others may be able to answer your queries.
31-08-2011, 07:40 AM
@Op ur ram cam run at 8-8-8-22 timings just set the timings manually in bios & the frequency to 592X2=1184
tighter timings will give better performance then 1600 freq.
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
31-08-2011, 08:50 AM
Adam young
^^will it?because someone told me that higher frequency gives more performance over lesser timings.I think that was not the cause for my problem i guess because it also happened before but that time i didn't change anything.
btw guys actually i ordered for corsair XMS3 RAM from SMC but they have sent me vengeance at the same cost and in invoice also it is written as XMS3.so guys will i see any problem claiming my warranty?
-Rifleman's Creed
31-08-2011, 09:07 AM
i think the higher frequencies will give performance boost in amd llano processors
for the warranty speak the matter with SMC did they mention any serial or part no.in the bill
31-08-2011, 11:39 AM
BMG ftw!!
^^ Then he may lose out his vengeance ram module(s).
31-08-2011, 11:49 AM
^^ the retail difference is i think Rs200 approx between the two i don't think smc will ask to return or pay extra for that if he purchased online they must have send it due to non availability of xms3
31-08-2011, 02:18 PM
Adam young
no serial number is mentioned just model number of xms3(CMX4GX3M1A1600C9) and its price.in that model number vengeance one just differ by that cmx where it has cmz,so i think the one packed the parts have misread it and sent this as there is just single alphabet difference.
-Rifleman's Creed
31-08-2011, 03:49 PM
i don't know corsair's warranty policy whether u need the bill or not but i think u should talk to then if in any case in near future u need the warranty & it requires the bill then u will be in trouble
31-08-2011, 10:08 PM
BMG ftw!!
@sukesh1090: Then first call corsair re-seller in India, and ask them what is needed for availing warranty on any product. If they say that bill is required, then only contact smc, otherwise why should you?
