Old 30-08-2011, 07:00 AM   #1 (permalink)
SuperMASSiVE
stonecaper's Avatar
Default Logical Partitions Gone
Today Morning My WD 1TB Drive's Logical Partitions are Not Showing.It Shows as unallocated Space in Windows Disk Management.
Have I Lost all the Data?
Please Help
Steve Jobs (February 24, 1955 – October 5, 2011) & Jagjit Singh (8 February 1941 – 10 October 2011)
RIP
stonecaper is offline   Reply With Quote
Old 30-08-2011, 07:36 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Logical Partitions Gone
probably some one accidently deleted the logical partitions run a chkdsk first to check drives health then try ontrack easy recovery
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-08-2011, 10:42 AM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
There are many software available over the internet to recover logical partitions along with data. use any one of it & you wil get back those partitions & data in it.
d6bmg is offline   Reply With Quote
Old 30-08-2011, 11:29 AM   #4 (permalink)
A link with a small guide that should help
How to Restore Deleted Logical Partition
Old 30-08-2011, 04:22 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@stonecaper. try this software >> Find And Mount <<
easy 2 use & effective ... works as ur virtual hdd
... W H O T ...
ax3 is offline   Reply With Quote
Old 31-08-2011, 04:22 PM   #6 (permalink)
ax3
ax3's Avatar
first also try renaming the drive & c if it works .
... W H O T ...
Old 31-08-2011, 10:02 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
I highly doubt it will work. But it will surely result in un-bootable PC, as Windows will not know the relative path to bootstrap.
Old 09-09-2011, 11:21 PM   #8 (permalink)
I also faced the same problem 2 month back,when all of my laptop partition was gone.
Actually what happen is system is not able to find partition table for ur drive and Possible reason is that it might become corrupt.
No need to worry, u can easily solve this issue..
Please take a look on this and let me know if u need any other help
Please help, I lost 500GB of data due to this program
silicon_fusion is offline   Reply With Quote
Old 10-09-2011, 12:52 AM   #9 (permalink)
BIOS Terminator
nims11's Avatar
happened with me couple of time. I deleted a logical partition and all the other logical partitions went to unallocated space.
use easeus partition manager to recover the lost partitions.
Free Data Recovery Software, Backup Software and Partition Manager Freeware in Windows and Linux - EaseUS
nims11 is offline   Reply With Quote
