Old 29-08-2011, 10:21 AM   #1 (permalink)
Blender Artist
Default System PowerOn Automatically without pressing power button
hi,
my system TurnOn Automatically without pressing power button. why?
anandharaja is offline   Reply With Quote
Old 29-08-2011, 11:30 AM   #2 (permalink)
Default Re: System TurnOn Automatically
Can you provide more info if possible ?
Probably you switched it off once during boot and hence this is happening.
Try refitting the PSU cables.
a Virus may be causing this too.Period
Old 29-08-2011, 11:53 AM   #3 (permalink)
Blender Artist
mostly my system turn-on automatically. some time i manually press power button.
what info you want about my system configuration or what?
Recently i updated my BIOS. iam not noticed before updating bios how my system started.
Before updating BIOS when ever i switch on my UPS i noticed DVD,HDD, and Power LED are on, at the time i pressed Power button 2 times to turn on my system, iam not sure my sytem boot at that time.
Old 29-08-2011, 12:45 PM   #4 (permalink)
Originally Posted by anandharaja View Post
hi,
Normally this happens when it's set in the BIOS to do just that. The exact location in BIOS and the exact wording in the menu may differ, but it's usually under something like "Power Management" and the sub-menu like "Power On after AC power loss".
Check the BIOS and if "Power On after...." is set to Enabled or On, just change it to Disabled or Off.
pimpom is offline   Reply With Quote
Old 29-08-2011, 01:22 PM   #5 (permalink)
Blender Artist
Thanks Pimpom, but After Power Failure Option is set to Stay Off.
here are the option i got under POWER Tab
Intel DynamicPower Technology.
Enhanced Intel Speed Step Technology <Enabled>
Processor C States <Enabled>
System Power Options
After Power Failure <Stay Off>
Wake On LAN From S4/S5 <Power-on Normal Boot>
Deep S4/S5 <Disable>
S3 State Indicator <Blink>
Wake System From S5 <Disable>
PCIe ASPM Support <Disable>
Flash Update Sleep Delay <Disable>
Old 30-08-2011, 05:59 PM   #6 (permalink)
anshul_sood's Avatar
Have you enable power on upon network or keyboard/mouse activity?
AMD phenom x2-555 BE
Asus M2N68 AM3 board
2x2 GB Corsair DDR3-1333
Sapphire Ati Radeon 4670
Samsung Syncmaster P2250
Windows 7 Ultimate x64
anshul_sood is offline   Reply With Quote
Old 30-08-2011, 10:12 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Config looks OK. So the problem is not related to BIOS.
Well, provide us detailed info about your config. (I think its PSU, which is under-powering the setup. )
d6bmg is offline   Reply With Quote
Old 31-08-2011, 09:09 AM   #8 (permalink)
Blender Artist
My System Config:
Intel DH67BL Mother Board
Intel i5 2500 Processor
Corsair 4GB 1600MHZ RAM
Seagate 1TB HDD
LG DVD Drive
Corsair GS600 PSU
CM Elite 310 Cabinet
Are you telling about these settings.
Old 31-08-2011, 10:12 AM   #9 (permalink)
That too and my bios has settings for wake from keyboard and wake from mouse options.
Old 31-08-2011, 10:29 AM   #10 (permalink)
kiranbhat's Avatar
load default bios setting and check again.
put all jumpers in default position.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
3gb Transcend DDR3 1333Mhz
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
kiranbhat is offline   Reply With Quote
Old 31-08-2011, 10:40 AM   #11 (permalink)
Blender Artist
Thanks for your replies. i set the Wake On LAN From S4/S5 <Stay-Off> .
now my system works fines. now i power on my system pressing the power button.
Old 31-08-2011, 11:37 AM   #12 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ Congrats then!!
Old 31-08-2011, 12:07 PM   #13 (permalink)
Blender Artist
Originally Posted by d6bmg View Post
^^ Congrats then!!
Thanks for everyone helping me to solve my problem.
What is the use of this option Wake On LAN From S4/S5
Old 31-08-2011, 03:33 PM   #14 (permalink)
kiranbhat's Avatar
if you have 2 or more computers on lan connected then you can wakeup all computers from 1pc
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
Old 31-08-2011, 05:45 PM   #15 (permalink)
No problem.
Old 31-08-2011, 09:59 PM   #16 (permalink)
BMG ftw!!
d6bmg's Avatar
Then for normal uses we don't need it & it should always remain disabled/off.
Old 01-09-2011, 09:18 AM   #17 (permalink)
kiranbhat's Avatar
ya mostly if we have server on lan then we need it,otherwise for day today use we dont need it
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
Old 01-09-2011, 09:50 PM   #18 (permalink)
BMG ftw!!
d6bmg's Avatar
^ Thankfully very few of us got server, so its useless.
Old 01-09-2011, 10:25 PM   #19 (permalink)
Stuck in Time...
Vyom's Avatar
I didn't quite understood why turning System On by default was a problem. Isn't it good that you don't have to press power on, when you switch on the Mains!
It should be the problem, when System would have been turning off randomly!
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 02-09-2011, 11:42 AM   #20 (permalink)
Blender Artist
i don't like to turn on my system automatically.
Old 02-09-2011, 07:42 PM   #21 (permalink)
BMG ftw!!
d6bmg's Avatar
Almost everyone wants to have more & more control over his/her own system. So, automatic start-up of system is really annoying.
