Old 28-08-2011, 10:59 AM   #1 (permalink)
Default zepronics bijli cleaning problem???
pals...
needed 2 know how to open my zebronics bijli cabby...
my front fan had 4 leds..but now only 1 glows...
so needed 2 check it out and also clean the cabby...
the problem is just that cant figure out how to open the cabby.....
help needed, if anyy 1 has teh same stuff and opened it...
thanx
angel
The Day Walker! is offline   Reply With Quote
Old 28-08-2011, 06:35 PM   #2 (permalink)
Default Re: zepronics bijli cleaning problem???
Here is a link for help -
How to open Zebronic Bijli's front panel ?
Old 28-08-2011, 07:26 PM   #3 (permalink)
I also googled and some where it was weitten to pull the front mesh out instead of the front panel completely. So wot should I do...
Old 28-08-2011, 09:32 PM   #4 (permalink)
JUst make sure no wires are connected to the panel when you remove it. Its safe to remove the full front panel. Dont try to force it open though. Dont use too much force.
Old 28-08-2011, 10:50 PM   #5 (permalink)
As such I have to remove my Mobo for fitting my cm hyper 212+. so will tru to do so then
Old 28-08-2011, 11:39 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
Don't you have any manual that cam with Zepronics bijli case? I hope there is detailed procedure about how to open/ attach every component of it.
d6bmg is offline   Reply With Quote
Old 29-08-2011, 12:29 AM   #7 (permalink)
Actually my case is 2 years old so I have nothing now..
Old 29-08-2011, 01:17 AM   #8 (permalink)
Zebronics cases typically don't come with any manual or such - they are generally straightforward cases anyway.
The Bijli case is a particularly hard one to clean. It has a porous design that simply allows dust through. Definitely not a great option if you live in a windy or dusty place. I had this case till very recently.
To open it, you need to pull at the edge near the screws at the back. It's quite a tight fit so it can be difficult, you need to put some pressure. Near the fans, there's a depression close to where the screws and wires are. Put your hand here and pull back hard.
(Other thoughts: Not exactly a "gaming" case to be honest. Zebronics have done better IMO in the past).
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
AcceleratorX is offline   Reply With Quote
