27-08-2011, 10:37 PM
system hangs
hey guys i'm using
asus p5g41t-m lx
intel dual core3ghz
1gb simtronics ram
windows7 32bit
no additional cards
but my system hang in bitween any time when i was working,and i have only option to press that damn 'restart' button. Even 'windows task manager' dose not work but asus pc prob and hw info says
cpu temp 42'c
vcore volt 1.27
plz urgent help me
i dont have any idea to what to do.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
3gb Transcend DDR3 1333Mhz
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
Reason: add info
28-08-2011, 12:26 AM
BMG ftw!!
Re: system hangs
what about your psu??
28-08-2011, 02:21 AM
Manchester United <3
Re: system hangs
His sig mentions it.
@OP
Check the RAM. Run memtest.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
28-08-2011, 07:39 AM
Re: system hangs
guys today i found another thing that after system hangs i removed ram and thats quit hot to hold in hand is that any problem,
cpu fan @1198rpm
and then i have add the another 90mm high speed fan to cpu side panel then it'll droped to around 890rpm
but still has problem.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
Reason: BAD language
28-08-2011, 10:02 AM
Adam young
Re: system hangs
if it is too hot then it is something to think about.but the RAM always gets heated up a bit.
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
28-08-2011, 12:43 PM
BMG ftw!!
Re: system hangs
cpu fan @1198rpm
RAM modules do get hot while running computer, but not too hot to hold them in hand.  Am I wrong?
28-08-2011, 12:44 PM
Super Moderator
Re: system hangs
Run the MEMTEST.
30-08-2011, 10:14 AM
Re: system hangs
guys i have downloaded memtest its a just 'kb' file and lose to burn bootable on cd so how can i boot from a usb pen drive to boot from it plz clearly say me.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
30-08-2011, 10:39 AM
BMG ftw!!
Re: system hangs
^^ Yes, you can boot memtest from usb pen drive.
30-08-2011, 11:17 AM
Super Moderator
Re: system hangs
Make the USB FAT32, change boot sequence to USB and boot via it. Let MEMTEST run.
30-08-2011, 08:21 PM
Re: system hangs
But how, i think only putting the only iso file in usb it cant boot can i need any another files,
because i had already tried the linux os iso but it never booted with only iso file.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
30-08-2011, 08:25 PM
Re: system hangs
Test if your system is capable of booting from a USB Device | USB Pen Drive Linux
30-08-2011, 09:54 PM
Re: system hangs
Download Lavasys Everest and run a system stability test. Will test memory and other components like proccy.
01-09-2011, 01:29 PM
Re: system hangs
GUYS i think my windows7 has sum problems so now i'll gonna remove it and put the xp sp2 back in my system .
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
01-09-2011, 02:57 PM
Re: system hangs
I have seen on your signature that your processor is being overclocked to 3.8ghz  and its a dual core right, try to run at stock speed if problem and tell me what happens
01-09-2011, 09:46 PM
Re: system hangs
i have already Tried every thing but nothing worked. and now installing xp back
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
01-09-2011, 10:02 PM
BMG ftw!!
Re: system hangs
AFAIK, OC'ing CPU have no bad effect on any software(s), specially OS.
02-09-2011, 10:23 AM
Re: system hangs
ya oc never effect the os. It shows bad things via automatic random restarting, and by heat.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
02-09-2011, 07:56 PM
#19 (permalink)
Re: system hangs
but it affect stability of system
02-09-2011, 10:54 PM
#20 (permalink)
Re: system hangs
ya but only affect when we do too much overclock, but i did only up to20% of its oc profile level means in mobo bios it has 5options 5% 10% 15% 20% AND test mode.
:lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX
E5700 oc to 3.8Ghz
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
03-09-2011, 09:06 PM
#21 (permalink)
Re: system hangs
Can you tell me exact model no. of CPU
04-09-2011, 02:40 PM
#22 (permalink)
Re: system hangs
offtopic @ OP: i am crazy with your avatar. pls pls pls share me the pic. will use as wallpaper.
04-09-2011, 02:50 PM
#23 (permalink)
Re: system hangs
04-09-2011, 05:16 PM
#24 (permalink)
Re: system hangs
@avichandana20000, alternately (in case you want to search some more pics) drop the pic/upload on Image Search on Google Chrome. it'll give you a list of pics as well as website of the same pic
05-09-2011, 12:38 AM
#25 (permalink)
Re: system hangs
thanks Ishu Gupta
^^ but i use oprea 11.51
