27-08-2011, 01:11 PM
Best External/USB Harddisk in 2000-3000 Rs.
Dear All,
Very soon I want to buy an external Hard disk of data backup. Size does not matter (Big is better).
It should have good build quality, Fast Speed etc.
Pls give some suggestion. My price range will vary from 2000 -3000 Rupees.
Thanks
27-08-2011, 01:17 PM
Manchester United <3
Re: Best External/USB Harddisk in 2000-3000 Rs.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
27-08-2011, 01:36 PM
thanks dear,
But does it support usb3.0 for future point of view.
thanks
27-08-2011, 01:38 PM
Originally Posted by sainit
thanks dear,
thanks
No, Western Digital My Book Essential 1 TB USB 3.0 Desktop External Hard Drive WDBACW0010HBK does
Simply a DIGITian
Performance Specifications
USB 2.0
Physical Specifications
Capacity 1 TB
Interface USB 2.0
Physical Dimensions
Height 1.42 Inches
Depth 7.01 Inches
Width 4.59 Inches
Metric
Height 36.14 mm
Depth 179 mm
Width 116.58 mm
Weight 1.02 kg
It doesn't support USB3.0
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
27-08-2011, 02:12 PM
BMG ftw!!
Originally Posted by Ishu Gupta
Sorry, but that model doesn't support USB3.0
Op have to go with WD My book Essential series for getting USB3.0 connectivity which cost around 3.5K.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
27-08-2011, 02:18 PM
Hmmmmm
Go for wd my book essential 1tb usb 3.0 @3.5k at flipkart.com.
Op have to go with WD My book Essential series for getting USB3.0 connectivity.
I pasted the same link again
EDITED
27-08-2011, 08:09 PM
Fullbring
@sainit: WD passport 3.0 is within your budget. try flipkart or ebay if u want online
27-08-2011, 10:15 PM
BMG ftw!!
EDITED
That's why I thought that that mistake must be due to wrong copy-paste, as wrong suggestion from you, is , unbelievable.
01-09-2011, 03:24 PM
go for Seagate one they are very hard drive manufacturer
01-09-2011, 03:29 PM
Manc
WD 3.0 1 TB or Seagate 2.0 1TB !
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
01-09-2011, 09:56 PM
BMG ftw!!
Why not Seagate 3.0 1 TB?
12-09-2011, 02:01 PM
I don't think letsbuy is a professional e-commerce website whose link has been given many times. I too clicked the link & have posted few queries. I also sent email & called their customer care account but no one replied. My suggestion is better avoid them.
Thanks.
12-09-2011, 03:39 PM
Hmmmmm
Where its available??
12-09-2011, 03:51 PM
Thanks.
So far, I have bought 3 phones, 1 hard-disk, 1 headphone, 1 steam-iron, and 2 pen drives from Letsbuy. All of them were delivered in maximum 3 days. So far, no complaints what-so-ever. And anyone who has traded with them will share the same experience. As of now, Letsbuy is one of the most trusted e-commerce sites in India. Dunno why you had such a bad experience contacting them, but from what I've heard, the site is quite good.
12-09-2011, 06:18 PM
Thanks.
Not as good as flipkart but still better than most others.
Nehru Place.
12-09-2011, 06:46 PM
#19 (permalink)
[QUOTE=Ishu Gupta;1492187]Not as good as flipkart but still better than most others.
I agree with you. Flipkart is good. I've bought i mobile from them & received it in 3 days. As far as comparison is concerned, I'm not as experienced in using their services, so I can't comment on that.
@aniket.cain - I have no idea.
