hello friends, i may be posting in the wrong section but i just have a general question. My laptops motherboard is dead and it wont turn on. I dont want to replace the mb, since its costly. My question is can i retrieve data of my hard drive. And any idea how much it may cost. Thanks in advance.
if the HDD of the laptop is ok u can do it how old is ur laptop if ur laptop has a sata HDD then u can plug in to any desktop & copy the data for that unplug ur HDD & see
Once you have removed the hard drive from your laptop.Please check the attached picture,it will help you recognize if your hard drive is SATA or IDE.Accordingly just buy a portable HDD casing (sata/ide) and connect your laptop Hard drive to it and plug it to any computer.You should be able to see your data.
A Backup is No Good If You cant Restore It !!!
