ya u read it rite. just like SRK`s haklana, my dvd riter doesnt rite properly. It rites on RW`s bt when its time on only dvd-r`s, it pops up error or aborts mission. have this liteon dvdr player. is it dead or on its way or any other thing ??? wasted my sony dvdr
here is log file :
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26 - 10 - 2004 5:35:34 PM
Nero Version: 6.6.0.8
Recorder: <LITE-ON DVDRW LH-20A1P> Version: KL0P - HA 0 TA 1 - 6.6.0.8
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <LITE-ON DVDRW LH-20A1P >Version: KL0P - HA 0 TA 1 - 6.6.0.8
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW LH-20A1P atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3250310SV atapi Port 1 ID 1 DMA: On
CdRomPeripheral : VWTMFO 70TMZST2R4X 1.03 ar8owrdk Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1P F: CDRom0
VWTMFO 70TMZST2R4X G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2037MB (2086316kB)
Free physical memory: 1478MB (1513724kB)
Memory in use : 27 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
26.8.2011
ISO compilation
1:51:00 PM #1 Text 0 File Isodoc.cpp, Line 6172
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
1:51:00 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
1:51:00 PM #3 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW LH-20A1P running
1:51:00 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
1:51:01 PM #5 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
1:51:01 PM #6 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2147327 (477:11.02, 4193MB)
1:51:01 PM #7 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
1:51:01 PM #8 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: LITE-ON DVDRW LH-20A1P, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
1:51:01 PM #9 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
1:51:01 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2147328 (2147328) = #2147328/477:11.3
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2147328 blocks [LITE-ON DVDRW LH-20A1P]
1:51:01 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [LITE-ON DVDRW LH-20A1P] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4397727744, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2147328 | lead-out | 1 | 0x41 | 0x00
1:51:01 PM #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
1:51:01 PM #13 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
1:51:01 PM #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
1:51:01 PM #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 12x (16,620 KB/s)
1:51:01 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
1:51:01 PM #17 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode
1:51:01 PM #18 Text 0 File Mmc.cpp, Line 21235
Set BUFE: SMART-BURN -> ON , SMART-BURN : ON
1:51:01 PM #19 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 0
DVD high compatibility mode: Yes
1:51:01 PM #20 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1:51:38 PM #21 Text 0 File Cdrdrv.cpp, Line 1287
13:51:38.765 - LITE-ON DVDRW LH-20A1P\H0 T1 : Queue again later
1:53:56 PM #22 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03CD0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x02 0x5E 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
1:53:56 PM #23 CDR -1135 File Writer.cpp, Line 311
Write error
1:53:56 PM #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
1:53:56 PM #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
1:53:56 PM #26 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was 155263
1:53:56 PM #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 12x (16,620 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9200 bytes, created 29 - 04 - 2009 1:50:06 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.83a, size=44944 bytes, created 29 - 04 - 2009 1:50:06 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.5512 (xpsp.080413-2108), size=96512 bytes, created 14 - 04 - 2008 12:10:32 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
