Old 25-08-2011, 06:24 PM   #1 (permalink)
Default Why did all the contents in DVD got corrupted?
It hurts; usually I use to make DVDs of such file which I have downloaded or got from any friend. This time I made so. And deleted the files from the Hard Drive. Now when I needed some of those file then I inserted the DVD and… fount that when I open:
exe file : it opens with CMD like application and closes
txt file : open with notepad (or appropriate app. but is blank)
7z file : “This is not a valid 7z archive.”
Jpg file : “No Preview Available” (Windows Fax and Image Viewer)
After all I want to say that all the content of DVD got corrupted/waste.
* I used Nero 6 in this case..
roushanrj776 is offline   Reply With Quote
Old 31-08-2011, 04:26 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Why did all the contents in DVD got corrupted?
am aso going through same. cd`s were more reliable than dvd. am now even scared 2 delete my data from hdd.
try isobuster, u might get lucky.
... W H O T ...
ax3 is offline   Reply With Quote
Old 31-08-2011, 08:27 PM   #3 (permalink)
Adam young
sukesh1090's Avatar
seems it was not written correctly.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 31-08-2011, 08:38 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
That is the problem with your DVD writer.
A tip: Do not use more than 4.10GB space in a normal DVD5 disk while creating a data disk.
d6bmg is offline   Reply With Quote
