Old 25-08-2011, 02:17 PM   #1 (permalink)
Default Need Help For Smps Power supply problem with 5 Hdd
I have pentium 3.00 with 5 Hdd and 1 dvd writer
Many times computer wont detect Hdd attached to raid card
i have 4 hdd attached to raid card , sometimes it detects 2 or 3 hdds only . sometimes all 4
but all hdd is working properly so there is 100 % no problem in hdd
some times it wont detect raid card also , if it dont detect raid card i open cabinet and remove the card slightly and then push it agian .
i want to know whether mine power supply or Smps is enough
i have Zebronics 400 W power supply . i think it is for 600 - 700 Rs
Question is should i get new smps and if yes for how much watts
Like 500 watts true power or which one
AMIT AGARWAL
AMITAGARWAL02 is offline   Reply With Quote
Old 25-08-2011, 03:08 PM   #2 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Default Re: Need Help For Smps Power supply problem with 5 Hdd
Your Post is in wrong section.
BTW did you tried connecting all the HDD's without RAID Card or with a different PSU ?
I know the PSU is a bad, but to handle 5 HDD's, IMO it should work fine.
Anyway check what i mentioned above & post the results.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
Old 25-08-2011, 03:11 PM   #3 (permalink)
laborare est orare
Cilus's Avatar
Pentium 3 motherboards are known to have problem to detect multiple HDDs and if the HDD size is higher than 160GB. Also 400W PSU is little underpower to power 5 HDDs along with other components. Get a 600-700W local PSU from Foxin, intex or Frontech, price will be within 700 to 900 bucks.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is offline   Reply With Quote
Old 25-08-2011, 04:03 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
Problem is with your mobo, not with PSU. (assuming that you don't have graphics card or sound card(s) )
d6bmg is offline   Reply With Quote
Old 26-08-2011, 12:24 AM   #5 (permalink)
why problem is with motherboard
i tried to remove 1 harddisk and it detects harddisks many times .
and i tried to remove any one hdd not any specfic one
i think should i go for higher smps or not
also i cant connect 5 hdd to motherboard without raid card as motherboard has only 1 ide port.
i don't have graphics card or sound card as it is builtin on motherboard.
i have 2 gb ddr 2 ram.
Speedfan shows this . can any expert tell me is power requirment low as it is 400 W Zebronics .
vcorea 1.36V
vcoreb 1.52V
+ 3.3 V 3.33V
+5 V 5.08V
+12 V 12.28V
-12 V 1.95V
-5 V 2.80V
+5VSB 5.59V
VBAT 3.20V
AMIT AGARWAL
Old 26-08-2011, 03:41 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
You have already got your answer. Your motherboard is too old to run 5 HDDs without any problem.
Listen to him.
Old 26-08-2011, 05:08 PM   #7 (permalink)
Listen to him.
50 % times 5 Hdds runs without any problems . if i remove 1 Hdd 70 % times no problem. if i remove 2 Hdd then no problem at all .
mine is 915 Motherboard
i want to know is Zebronics 400 W power supply enough
AMIT AGARWAL
Old 26-08-2011, 08:55 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Bad PSU. But even then your board would not support.
asingh is offline   Reply With Quote
Old 26-08-2011, 10:39 PM   #9 (permalink)
I was asking which smps to buy
400 w or 500 w true power supply - vip brand - it is above Rs 2000
AMIT AGARWAL
Old 30-08-2011, 12:40 AM   #10 (permalink)
board is supporting sometimes like in 10 times start it is supporting 7 times all 5 hdd
but i think when there is power problem the computer after starting windows disappears any one hdd
+ 3.3 V 3.33V
+5 V 5.08V
+12 V 12.28V - now it shows 11.05 or 11.31 many tims
AMIT AGARWAL
Old 30-08-2011, 12:52 AM   #11 (permalink)
BMG ftw!!
d6bmg's Avatar
And your budget for buying new PSU?
P.S. don't go for any cheap brand like vip.
Old 08-09-2011, 01:18 AM   #12 (permalink)
YES I HAVE TAKEN iball power supply 500 watts and everything is ok now
no graphics card and no sound card
NO I dont think so , mine motherboard supports 6 HDDS
Listen to him.
no he is wrong
only 1 thing i dont understood
Enhanced dual +12V output capability - it has 12V1 and 12V2
how to connect that
i have connected main powersupply 20 pin into 20 pin and 4 pin motherboard cable to motherboard . now where is that 12V cable to connect .
AMIT AGARWAL
Old 07-11-2011, 02:15 PM   #13 (permalink)
now everything is ok
i have put 6 hdds (includes sata hdd also) and changed the power supply
power supply was giving problems not motherboard
so the suggestion was wrong for changing motherboard .
AMIT AGARWAL
Old 07-11-2011, 02:21 PM   #14 (permalink)
d3p
d3p's Avatar
^ as mentioned earlier.
IRC Krow
Old 25-11-2011, 02:12 AM   #15 (permalink)
thanks
AMIT AGARWAL
