I have a FreeAgent Go 500GB HDD that is still in warranty. I was planning to rip the covering off the hard drive and use it as my Internal HDD for my Macbook Pro 13".
Is it possible?
My Macbook Pro13" has only a 160Gb HDD only! I'm planning to use the external HDD as my internal and by saving cash there I can invest in a 2Tb external HDD.
I just wanted to know if the connectors that are used in the Seagat Freeagent Go HDD are the same as that of a norma 2.5" HDD.
Music is the opiate of life and I’m stoned all the time.
MacBook Pro 13”
Aural Nirvana : Audio Technica CK10:-D | Panasonic RP-HJE900 | Alessandro MS-1 Last.fm
i think the Go flex drive will allow to do that without ripping off the case, again do it at ur own risk the connectors look identical to the normal sata data and power
