I purchased a corsair vx450 for my system a couple of months earlier and i've been using it since then.So far,it has worked properly and i have not faced any problems with it at all.However,of late,it has started emitting a low-pitched jittery noise that sounds a lot like "kirrrrrrrrr" while my PC is on.I have no idea whether this is normal or not.I have checked my system thoroughly and it doesn't seem that something else is causing this annoying sound.
This worries me greatly as the cooler master PSU i had earlier also generated a lot of noise(which sounded quite different though) before it began to malfunction.According to the technical details that are available on corsair's website,this PSU is supposed to be "ultra quiet"-hence a properly working vx450 should not emit any kind of noise.Now i have started to question the reliability of this PSU-it may not be as good as most of us usually think.
As far as i know,several members of this forum own this PSU-has anyone faced a similar problem with it?What should i do now?I feel really disappointed as i was under the impression that this PSU is extremely reliable.
