Old 20-08-2011, 09:09 PM   #1 (permalink)
radonryder's Avatar
Default system restarted during drive scan.now not working
So i was running a scan on my external Imation HDD for errors.It had to be unmounted to do so.I cliked the dialong box that did so.And it was scanning so was isntalling something and the computer restarted mid scan and now the drive shows up without any space under it and when i try to run scandisk it says the drive,path or file is invalid or something.It shows under my safely removeable disk.I tried the ontrack recovery software and it is jsut stuck at the scanning drives option.Please help guys that 1 tb hard was literally full
Thanks in advace
Edit 2/09 : guys problems started again
I have created over a thousand blades.Unknown to death.Nor to life.Have withstood pain to create many weapons.Yet,those hands will never hold anything.so i pray,"Unlimited Blade Works"
radonryder is offline   Reply With Quote
Old 20-08-2011, 09:31 PM   #2 (permalink)
Dust in the Wind
Skud's Avatar
Default Re: system restarted during drive scan.now not working
Don't understand the unmounting part, you were scanning through Windows (running chkdsk) or what?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 20-08-2011, 09:38 PM   #3 (permalink)
radonryder's Avatar
Originally Posted by ArjunKiller View Post
Buy a new computer.
-_- its an external drive dickhead.
if you need to troll someone go elsewhere.
neither did i tbh when i tried to scan it it said the drive needs to be unmounted for it to can/fix errors so i cliked yes on the dialog box.
Old 20-08-2011, 09:43 PM   #4 (permalink)
Gamer
Control Panel, open System, go to the Advanced tab, click Settings under Startup and Recovery, remove the check from "Automatically Restart" under System Failure. This will cause the system to blue screen instead of restarting on errors and the information on the blue screen may give a clue as to the source of the issue.
Hehe, sorry for trolling.
ArjunKiller is offline   Reply With Quote
Old 20-08-2011, 09:54 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
OK, remember, whenever you try to scan an external disk which was still accessed by some other program, then that unmount message come.
Now try to access the drive from a Linux LiveCD like Ubuntu. Try to access the drive after mounting and do some file operations. In my case, it has helped a couple of times.
Gaming Rig:
HTPC Rig:
Old 20-08-2011, 10:26 PM   #6 (permalink)
avichandana20000's Avatar
Buy a new computer.
do not give junk comments and waste our time.
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 20-08-2011, 11:07 PM   #7 (permalink)
radonryder's Avatar
OK, remember, whenever you try to scan an external disk which was still accessed by some other program, they that unmount message come.
Will do.
Cheers mate
Old 21-08-2011, 12:39 AM   #8 (permalink)
format from linux (as suggested by Skud) should fix it. in case it doesn't, try using this: HP USB Disk Storage Format Tool
PS: have tried it only many pen drive, but never on an external HDD. not sure if it'll be able to recognize it.
Old 21-08-2011, 07:45 AM   #9 (permalink)
Dust in the Wind
Skud's Avatar
Actually if you are lucky, you don't need to format it. Linux generally recognizes the disk after chkdsk interruption messed up.
Gaming Rig:
HTPC Rig:
Old 22-08-2011, 04:35 PM   #10 (permalink)
radonryder's Avatar
Error mounting: mount exited with exit code 13: ntfs_attr_pread_i: ntfs_pread failed: Input/output error
Failed to read NTFS $Bitmap: Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
Tried to open it in linux that error came.
so guess i'll have to format it then?
Old 22-08-2011, 06:41 PM   #11 (permalink)
Mmmph!!!
doomgiver's Avatar
no, you dont. run "/chkdsk <drive letter> /F" from admin command console.
this will do the trick.
my system froze too, with the exact same error (mine was a windows partition, so i had to use a mini-xp booted from a pen drive to run the command)
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 22-08-2011, 06:51 PM   #12 (permalink)
Dust in the Wind
Skud's Avatar
Yeah, run the chkdsk.
Gaming Rig:
HTPC Rig:
Old 22-08-2011, 09:01 PM   #13 (permalink)
BMG ftw!!
d6bmg's Avatar
for more details.
Your file system in the disk, (i.e. NTFS) is corrupt. You make try running chkdsk(check disk) but I don't think it will solve your problem. Best way is to format the drive completely.
d6bmg is offline   Reply With Quote
Old 22-08-2011, 10:33 PM   #14 (permalink)
Mmmph!!!
doomgiver's Avatar
oh no dude, most certainly NOT.
do the chkdsk FIRST.
as i've personally had this same problem, i can tell you exactly what to do.
formatting is a very extreme solution, do it only if NOTHING else works.
Steam : doomgiver
Old 23-08-2011, 01:57 AM   #15 (permalink)
radonryder's Avatar
dude Thanks a lot.
It is Scanning(just started 5 mins back).Slowly but it is.
praying it will fix it.
Old 24-08-2011, 04:53 PM   #16 (permalink)
Mmmph!!!
doomgiver's Avatar
Talking Re: system restarted during drive scan.now not working
checkmate.
Steam : doomgiver
Old 27-08-2011, 01:07 PM   #17 (permalink)
radonryder's Avatar
alright so now the thing is working but a lot of the files seem to be corrupted.tried using o & o recovery and its pretty much stuck.Any more advice guys?
im thinkin when i can i'll recover what data i can and reformat it.but again thanks yiu guys a lot of the stuff in there was irriplaceable and not everything seems to be curropted.you guys sure saved my backside
Old 27-08-2011, 11:28 PM   #18 (permalink)
Mmmph!!!
doomgiver's Avatar
try recuva... always worked for me
Steam : doomgiver
Old 29-08-2011, 01:52 PM   #19 (permalink)
radonryder's Avatar
Recuva is onyl showing the files i had deleted.
Nearly all my media files on it seems to have been corrupted
Old 29-08-2011, 06:49 PM   #20 (permalink)
BMG ftw!!
d6bmg's Avatar
there u go: Downloads » Freeware Tools » Page 1 - www.hiren.info
download Raw Copy 1.2
Old 02-09-2011, 01:34 PM   #21 (permalink)
radonryder's Avatar
ok so same problem started again
cannot access it in linux(same error as ebefore)
and in cmd im getting cannot directly access the volume error when trying to use chkdsk J: /f.
do help guys
Old 02-09-2011, 05:03 PM   #22 (permalink)
Mmmph!!!
doomgiver's Avatar
did you use 'run as admin' when you ran the command prompt???
Steam : doomgiver
Old 02-09-2011, 06:19 PM   #23 (permalink)
radonryder's Avatar
yes i did use the run as admin
Old 02-09-2011, 07:47 PM   #24 (permalink)
BMG ftw!!
d6bmg's Avatar
Now it sounds like a partially corrupt hdd, although I'm not totally sure.
Old 02-09-2011, 10:42 PM   #25 (permalink)
Mmmph!!!
doomgiver's Avatar
well, try running it from mini-XP from Falcon Four boot cd
FalconFour’s Ultimate Boot CD/USB 4.5 « FalconFour’s Perpetual Musings
if this doesnt work, nothing will.
Steam : doomgiver
Old 22-09-2011, 11:30 AM   #26 (permalink)
radonryder's Avatar
ok so somehow managed to get it working a bit.so now i have a 150 gb partition that seems to be working fine and the remaining 780 gb is in anotehr aprtition
but i cant seem to farmat it.it says windows cant format it
Old 22-09-2011, 12:47 PM   #27 (permalink)
abhidev's Avatar
try making an image of the partition...format that particular partition to resolve the file system issues...not sure if this would help...
check it out if its relevant
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 22-09-2011, 02:45 PM   #28 (permalink)
Fullbring
Zangetsu's Avatar
try formatting using command prompt...this works when windows format method fails.
else use partition wizard home (a free tool but good one)
