Re: RAM Problem!
Originally Posted by The Day Walker!
Pals
I have C2D E7500
P5KPL-AM/PS 0502 bios
1GB x 4 DDR2 pc2-6400 ram
Windows XP 32bit
The problem is the system is showing 1.99 gb ram installed in windows properties while cpuz is showing 4 gb installed. I know XP should show around 3.2gb ram installed instead of 4, but 1.99 ?
Wits the problem?
Help needed
Thanx
Angel
Ur MB has only 2 ram sloths how can u put 1GBX4 sticks in it
also ur MB supports 4GB max Ram i.e 2 x DIMM, 4 GB, DDR2 1066*/800/667 Non-ECC,Un-buffered Memory
So, i think 2GBX2 is supported a single 4GB is not try updating the bios & see
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
