Old 18-08-2011, 07:22 AM   #1 (permalink)
digitalpainter
digibrush's Avatar
Default Lost USB port!
It was started 5/6 days ago.
My usb Mouse was not working. No light on mouse...
After changing the USB port its working well until second day. Again no light on mouse. change to another port it is working well.
I checked top two port with my other USB device, they were not working except second port which only working with camera cable. But i also lost it yesterday night.
Today morning my pen tablet was not working. windows does not detect the device...after reconnect the cable on the same port it is working till now but i am afraid that i am going to lost my third port.
I dont make any hardware changes in one last month.
So friends, please help with this issue.
Intel DH55TC/Core i3 2.93Ghz/corsair Ram(4x2gb1333)/Sapphire HD5670 1Gb/Seagate 1Tb+500Gb/Seagate1TB External/CM Elite 430 & Real power Pro 460W/Creative Audigy+Inspire/iball pentablet/Razer Abyssus//Razer Goliathus/DellST2220L/Windows 7 Ultimate 64 bit.
It's good to touch the green, green grass of home.
digibrush is offline   Reply With Quote
Old 18-08-2011, 11:51 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Lost USB port!
RMA ur MB & explain ur problem to them properly if possible give them a written note with the MB before that try using linux to verify that it is a hardware problem
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 18-08-2011, 09:07 PM   #3 (permalink)
Well, what I say you to do is to check PSU with another PC if possible?
Try to reset BIOS with removing CMOS battery. Also try re-installing mobo drivers to see if it helps.
Also do a PC cleanup using CCleaner
CCleaner - Optimization and Cleaning - Free Download
Old 18-08-2011, 11:40 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Just overlay your chipset drivers once again.
asingh is offline   Reply With Quote
Old 19-08-2011, 04:57 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
yep, reinstalling driver might fix this issue and if it does not Do a fresh install of the OS and download and install the latest chipset driver and see if it works.
ToPsPeEeD = FaSt BuT StEaDy
Old 19-08-2011, 01:13 PM   #6 (permalink)
digitalpainter
digibrush's Avatar
Thanks @mithun_mrg, thetechfreak, asingh & topgear.
I re install latest chipset driver from 'downloadcenter.intel.com' for my MB, but my problem remain same.
No news of new USB lost....
But those USB(lost) port has power...I test with my USB light.
dont work with other USB device like: Mouse, Scanner,Camera even with USB headset.
Is there any other ways to solve the problem?
Old 19-08-2011, 01:27 PM   #7 (permalink)
mithun_mrg's Avatar
Try reinstalling the os or use ubuntu live & see usb is working or not else RMA
Old 19-08-2011, 01:30 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
@digibrush: Its a problem with USB I/O drivers...reinstalling will fix it
Old 19-08-2011, 01:37 PM   #9 (permalink)
digitalpainter
digibrush's Avatar
Thanks guys, I'll try with ubuntu live.
Can you tell me where I can find USB I/O drivers?
Old 19-08-2011, 03:16 PM   #10 (permalink)
Adam young
sukesh1090's Avatar
try ma-config.com.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
