Old 16-08-2011, 01:06 PM   #1 (permalink)
ajayritik's Avatar
Default Front USB Ports stopped working
For the past few days I observe that the front USB ports are not working properly. Once in a while they do work but it not working everytime. I checked if the back ports have any issues. There seems to be no issue with the USB back ports.
What should I do to fix this? Also when I use a pen drive which has harder grip I don't face the problem. Do I need to replace the panel or check the internal wiring?
ajayritik is offline   Reply With Quote
Old 16-08-2011, 01:12 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Front USB Ports stopped working
I too have the same problem but not with USB...its headphone jack in front panel...
Old 16-08-2011, 01:26 PM   #3 (permalink)
kool's Avatar
Mine too headphone/microphone never worked. its cable are not compatible with ASUS MB. and one USB has stopped working. any solution?
►► ◄◄ :smile::smile:
kool is offline   Reply With Quote
Old 16-08-2011, 04:11 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Usually happens when the connectors get rusty. Same with my CM690 front panel USB ports. At times they catch, and sometimes they do not.
asingh is offline   Reply With Quote
Old 16-08-2011, 05:21 PM   #5 (permalink)
ajayritik's Avatar
What about the solution for this?
Old 16-08-2011, 05:36 PM   #6 (permalink)
Hmmmmm
Tenida's Avatar
You need HD audio header to enable front panel audio.Most the budget cabinet comes with AC 97 header.
You have to buy new front side usb header like these......
Tenida is offline   Reply With Quote
Old 16-08-2011, 09:22 PM   #7 (permalink)
Adam young
sukesh1090's Avatar
^^ where to get these?
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 16-08-2011, 09:35 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Most computer markets have 'em.
Old 16-08-2011, 10:10 PM   #9 (permalink)
Sin
Have you tried changing BIOS setting to AC 97 from default selected HD option in the CHIPSET section of the motherboard ?
It worked for me.
»~$in~«
sinoop_joy is offline   Reply With Quote
Old 18-08-2011, 11:32 AM   #10 (permalink)
kool's Avatar
What about cost? And how to put in CPU CABINET?
Old 18-08-2011, 10:28 PM   #11 (permalink)
avichandana20000's Avatar
if any one of the front usb works can a usb hub be attached to it?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 18-08-2011, 10:35 PM   #12 (permalink)
Hmmmmm
Tenida's Avatar
About 200 bucks.
