Old 14-08-2011, 08:02 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
superboysahil's Avatar
Default Unscrewing Creative SBS 245??
I want to open up creative SBS 245 speakers but cannot find the screws... can any1 tell me how can i do it?
superboysahil is offline   Reply With Quote
Old 14-08-2011, 10:38 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: Unscrewing Creative SBS 245??
why you want to open it?If you don't have any knowledge about the hardware then it is not recommended to open it.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 14-08-2011, 10:48 PM   #3 (permalink)
out of curiosity... i don't use it much so why the hell i stop myself... also i can treat it as a piggy bang and hammer it... but i'm not stupid... I'm an engg student nd it urges me to split it properly...
Old 14-08-2011, 11:05 PM   #4 (permalink)
Adam young
sukesh1090's Avatar
then good luck with your experiment.i think it could be somewhere beneath the sponge stickers or any other stickers.
-Rifleman's Creed
Old 14-08-2011, 11:10 PM   #5 (permalink)
nope not there....
Old 15-08-2011, 03:02 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
Originally Posted by superboysahil View Post
nope not there....
Please refer to corresponding user guide/ manual.
Do that only if your speaker is out of warranty period. otherwise you will lose your warranty on your hardware.
d6bmg is offline   Reply With Quote
Old 16-08-2011, 08:28 AM   #7 (permalink)
mithun_mrg's Avatar
u need to pull out the front dust filters to access the speakers screw but removing the screws may hamper the warranty as well as the sound quality also there is nothing much that u can discover in there
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 17-08-2011, 03:40 PM   #8 (permalink)
well its not discovering as such... the ON/OFF button has some problem.. it doesn't clings to ON position... i just want to rectify that... and yeah.. warrant is void too... anyways... thank you...
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/145107-unscrewing-creative-sbs-245-a.html
Unscrewing Creative SBS 245?? This thread Refback 26-10-2011 09:03 PM
