10-08-2011, 01:45 PM
rated R
speakers for ps3
Guys my brother has a ps3 and tata sky hd hooked up to a samsung 40" led TV.
Now we want to buy a 5.1 surround setup that will basically be used for both the tata sky and gaming...
I thought of the logetic z5550 and checked them out in croma.
MIND BLOWING sound..
but the problem is how to connect them to the TV?
the tv has one spdif port and 4 hdmis..
What to do?
Any other setup within 20k?
10-08-2011, 02:12 PM
Bond, Desi Bond!
Re: speakers for ps3
model number of the TV please!
10-08-2011, 02:17 PM
I am the night! I am....
@ ritvij
Z5500 cannot be connected to a tv and if you even manage to do it, there will be considerable audio loss.
They are strictly pc speakers.
You need an AVR along with speakers setup for your ps3 and tata sky.
Try onkyo TX-SR307 AVR alongwith onkyo SKS-HT528 5.1 speakers.
The bundle should cost you 20-25k and will be an ideal setup for your tv and ps3 as well as dth.
This is the cheapest and practical solution imo.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
10-08-2011, 05:03 PM
BMG ftw!!
10-08-2011, 05:28 PM
iDota
10-08-2011, 05:58 PM
^^ Yes, this package looks good. If available in a reasonable price, op should grab it.
Any pricing info mate?
10-08-2011, 06:28 PM
TDF Sucks
He can connect Z5500 directly to PS3 via SPDIF.
TDF Sucks.
10-08-2011, 06:48 PM
iDota
I saw the HT-S3300 for 22k long back. Don't know if HT-S3400 are priced same or more.
iDota
[quote]
10-08-2011, 06:50 PM
I don't think ps3 can decode DTS audio. An AVR is needed for that.
Should be within 25k. Someone has to confirm.
10-08-2011, 06:52 PM
iDota
Are you sure about this?
I have a PS3 but never checked.
10-08-2011, 06:53 PM
You've connected it directly to tv?
Read this - How to use Dolby TrueHD and DTS-HD with your PS3.
I guess an AVR (audio,video receiver is required).
10-08-2011, 09:55 PM
TDF Sucks
AFAIK Dolby TrueHD(it has 7.1 channel Dolby option in Speaker settings and Dolby digital is only 5.1) can be done directly, however not sure about DTS-HD (i think it can too).
BUT if you are using SPDIF out from PS3 to Z5500 , the question of decode does not arise, because the Z5500 is dolby digital capable, and he will not be able to take advantage of 7.1 channel audio.
I dunno, but if the Creative GigaWorks S750 also has SPDIF, he can consider it.
TDF Sucks.
10-08-2011, 10:23 PM
iDota
Looks like the coaxial, spdif and optical ports dont carry Dolby Digital TruHD. HDMI means need for an AVR
10-08-2011, 11:50 PM
Nope the z5500 cannot decode DTS-HD directly. You need to have an extra hardware that can do it and channel to the speakers. AVR's and PC soundcards(including motherboard onboard audio) are the only devices that can do it.
Simply put. SPDIF or optical toslink or coaxial cables do not have the bandwidth to carry DTS-HD & Dolby TrueHD.If you connect your Blu-ray player to your receiver with optical or coax, the audio will "fall back" to Dolby Digital, DTS or two-channel PCM (lossless, but only two channels).
Here HDMI connectivity is need and even previous 1.0 standard will suffice. Thus the dire need of an AVR arises. Simply a z5500 will not be enough here.
Dolby TrueHD & DTS-HD codecs can pack 8 channels of lossless audio. Each channel has 24 bits having a sampling rate of 96khz.This sampling frequency is twice the 48 kHz standard commonly used with audio on professional video equipment.
Getting down to the basics, sampling is nothing but conversion of a continuous analog signal into a discrete digital signal by taking number of samples per unit time. The Nyquist shannon theorem suggests that in order to recreate a perfect and lossless discrete signal from a continuous analog signal, the sampling frequency should be twice than that of the original frequency of the continuous signal being sampled. If lower sampling rates are used, then there will be considerable loss as the original signal wont be recovered.
Now DTS-HD has a 96khz/24bit resolutions that equates to 281.25kbps and SPDIF maximum supports 48khz sampling rate with a resolution of 24bits that equates to 140.62Kbps.
Note that the above represent bandwidth per channel.
Spdif supports only 2 channels whereas DTS-HD has 8 channels. So simply put spdif will be a huge bottleneck while transmitting DTS-HD or DOLBY TRUEHD.
Therefore connecting Z5500 to ps3 will result in two channel output along with reduced lossy bandwidth due to the above mentioned reasons.
So an AVR is absolutely required in this scenario.
11-08-2011, 03:51 PM
TDF Sucks
Thnx for the info, but what I was saying was that since he will use 5.1 surround, the question of 7.1 decode doesnt arise. I was saying that Z5500 can do Dolby Digital (which is 5.1), so AVR may not be needed in 5.1. I am not sure if it can do normal DTS.
TDF Sucks.
11-08-2011, 09:14 PM
^^ The quality will be bad and getting a z5500 in this scenario is a total waste. Those are strictly pc speakers and spdif nowadays don't make any sense since the advent of hdmi.
If you want 5.1 lossless audio AVR is the only way to go. The ps3 has the ability to decode LPCM (linear pulse code modulation) and send it to any receiver.
11-08-2011, 10:55 PM
TDF Sucks
Ok then.
TDF Sucks.
