Old 10-08-2011, 07:38 AM   #1 (permalink)
deepak_ds's Avatar
Default monitor problem
I have a 17" Compaq 7540 CRT monitor. It has been a few days that our monitor is showing a really strange problem. Actually I am confused whether it is software problem or hardware problem.
So the problem is that the display setting menu of the monitor is automatically displayed sometimes and it automatically goes away too. Sometimes the display setting too are changed! Even when i was writing this, that same problem appeared.
Is it a software problem(like virus) or hardware problem...!!?? confused:
deepak_ds is offline   Reply With Quote
Old 10-08-2011, 08:34 AM   #2 (permalink)
saswat23's Avatar
Default Re: monitor problem
AFAIK a software is not respnsible for Monitor's menu as it purelyu depends on the user. So, probably its some type of H/W prob.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 10-08-2011, 08:57 AM   #3 (permalink)
If you mean the monitor's own menu and not the OS's display settings menu, then the problem is probably a hardware issue. Some monitors display a message when the software setting is outside its sync range, for example when an LCD monitor is not set at its native resolution. But in this case, the problem is probably with the monitor itself.
Have you been having wet weather for some time? I've said this many times before in the forum: Electronic circuits are sensitive to moisture. Products that have been in use for months or years accumulate dust inside and the dust makes things worse because it retains the moisture. That can make strange things to happen and sometimes causes permanent damage.
If moisture is the culprit and if no permanent damage has been done, the solution is to clean and dry out everything inside. But opening a monitor is not a practicable option for the average end-user. What you can do is to leave it out in the sun for a long time - several hours at least. It should not be powered on during that time, of course.
pimpom is offline   Reply With Quote
Old 10-08-2011, 02:29 PM   #4 (permalink)
deepak_ds's Avatar
yeah
Old 10-08-2011, 05:07 PM   #5 (permalink)
BMG ftw!!
d6bmg's Avatar
5 years back I had a crt monitor which started same problem as you have stated here. Sadly except for opening everything there is no solution of it as crt monitor servicing is very rare. So just wait for your monitor to be completely dead (mine took 7 months or so) then buy new monitor.
d6bmg is offline   Reply With Quote
Old 10-08-2011, 10:23 PM   #6 (permalink)
deepak_ds's Avatar
Great then. Thanks for sharing your experience d6bmg.
Old 12-08-2011, 06:36 AM   #7 (permalink)
deepak_ds's Avatar
So suggest me a good LED LCD monitor within 9k?
And should i go for a full HD or a HD ready one?
Old 12-08-2011, 11:43 AM   #8 (permalink)
Fullbring
Zangetsu's Avatar
obviously Full HD...stay away from HD Ready.
Old 12-08-2011, 06:50 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
Benq G2220HD @ 7K
Old 16-08-2011, 04:55 PM   #10 (permalink)
Monitor problem arises due to continuous forcible shutdown from the UPS,due to pressure on CPU.
gghjk is offline   Reply With Quote
Old 16-08-2011, 11:34 PM   #11 (permalink)
Stuck in Time...
Vyom's Avatar
What!
Could you explain that, in a more technical language??
@OP: Dude, the display menu of Monitor getting auto displayed at random times, could just also be the sign that Menu buttons on the Monitor are the culprit. Just get it checked from someone who knows a little hardware. Maybe just the dust, can be a reason.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 17-08-2011, 12:49 AM   #12 (permalink)
deepak_ds's Avatar
Okay. I'll try this ASAP. Hope this works.
