Old 06-08-2011, 09:46 PM   #1 (permalink)
Pirate Slayer
Cool Comps's Avatar
Default Weird Problem
Guys i know this isnt the place to post this but plz bear with me.
My computer switches on but the monitor doesnt recieve any signal and it displays a message " No signal recieved " which i used to get when i switched off the comp.
ok now i disconnected the monitor and checked if it was working on my old shitty pc
it worked. I connected it back to my comp. It worked!
But for the past 2-3 days this has been happening. The monitor remains black and after some tries it boots. Today though i had to w8 for veryy long!
BTW so i went for startup repAIR ON WINDOWS. It displayed " Windws cant repair this comp automatically"
However the comp booted. Lets see if this re occurs.
UPDATE::the problem did re occur. Sometimes the monitor doesnt detect signal. Other times the monitor shows the boot up screen and evrything is normal.
BTW can it also happen because of software? because AFAIK it has started to happen after i updated to catalyst 11.7 via my control centre.
Should i uninstall and go back to 11.5?
Suggestion plz ASAP!!
Any sugesstions?
CPU : i5 2500 | Motherboard: Intel DH67BL | RAM: 4 gb corsair vengeance | HDD: 1 tb seagate |
GPU :Sapphire HD 6870 | PSU :Corsair TX650 v2 | Cabinet : CM Elite 430
Cool Comps is offline   Reply With Quote
Old 06-08-2011, 10:12 PM   #2 (permalink)
knocking on heavens door
sumonpathak's Avatar
Default Re: Hardware Price Check and Buying Advice Thread (Kolkata)
erm...check the GPU?
i5 2500k @ 4GHZ|E7500 @ 3.80GHZ|Athlon II X3 425 @ 3.68GHZ|Phenom II X4 965 @ 4.21GHZ|FX-8150 @ 5GHZ
P8Z68 Deluxe|Z68X-UD4|G31M-ES2L|Crosshair V Formula | 880GM-USB3 | M4A785T-M
HD 6870|HD 5450 2GB|Geforce 9400GT 1GB DDR2|Geforce 8400GS 512 MB DDR2
Corsair Value Select DDR3 review
A guide to Benchmarking world
FX 8150 Review
sumonpathak is offline   Reply With Quote
Old 06-08-2011, 10:21 PM   #3 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
Any sugesstions?
i dunno why, but people around me are having the similar problem. I also want to know the solution to this!
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is offline   Reply With Quote
Old 06-08-2011, 10:28 PM   #4 (permalink)
Pirate Slayer
Cool Comps's Avatar
^^ Try unplugin monitor. Then plug in again
Old 06-08-2011, 10:41 PM   #5 (permalink)
Hmmmmm
Tenida's Avatar
Any sugesstions?
Try to reset your bios once
Tenida is offline   Reply With Quote
Old 06-08-2011, 11:11 PM   #6 (permalink)
Pirate Slayer
Cool Comps's Avatar
@tenida: I couldnt even reach the intel screen. haha
Old 06-08-2011, 11:26 PM   #7 (permalink)
→|Requiescat| |in| |Pace|
soumo27's Avatar
^^Might be a GPU issue...
__Phenom X2 550 BE @ 3.3 Ghz | Asus M2968AM-PLUS | Kingston 2 GB DDR2 | Seagate 500 GB | Sapphire HD 6670 1 GB | FSP SAGA II 500 W :twisted: | X360 Controller__
soumo27 is offline   Reply With Quote
Old 06-08-2011, 11:27 PM   #8 (permalink)
Hmmmmm
Tenida's Avatar
Arey you have to reset(bios) jumper in the motherboard.
Old 06-08-2011, 11:39 PM   #9 (permalink)
Pirate Slayer
Cool Comps's Avatar
yh but as i said it worked for now so lets see if the problem will re occur
if it does then i will try advanced trouble shooting.
Old 07-08-2011, 02:24 PM   #10 (permalink)
Pirate Slayer
Cool Comps's Avatar
Originally Posted by topgear View Post
^^ Make a thread in Broadband and Communication section
@ Cool Comps - it would be better if you and others who are facing such issue make a thread on Hardware Q&A section so that others can see and suggest you some more solutions - Hint : sometimes moisturizer cause such issue in rainy season if there's AC inside of the room - so it's best to put some packet of silica gel inside of the cabby
BTW, MD guys told they will bring some Arctic cpu thermal paste - if anyone is going there don't forget to ask them if they have some other cpu thermal paste other tha CM Thermal Fusion
It does? Where to get silica gel and what is it
btw the problem did re occur. Sometimes the monitor doesnt detect signal. Other times the monitor shows the boot up screen and evrything is normal.
Old 07-08-2011, 02:36 PM   #11 (permalink)
Dust in the Wind
Skud's Avatar
But I face similar problem a couple of times, despite having a silica gel in place.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 07-08-2011, 02:43 PM   #12 (permalink)
Pirate Slayer
Cool Comps's Avatar
^^ even you? Your monitor doesnt detect any signal on startup?
which version of catalyst are you on?
It started happening to me after i updated to 11.7 from 11.5
You think i should uninstall and then reinstall 11.5?
I am just scared ill ruin the situation even more.
The warranty will be voided.
Old 07-08-2011, 02:58 PM   #13 (permalink)
Dust in the Wind
Skud's Avatar
It happens rarely to me, 1-2 times so far. Haven't really though much about it.
Gaming Rig:
HTPC Rig:
Old 07-08-2011, 03:08 PM   #14 (permalink)
Pirate Slayer
Cool Comps's Avatar
which drivers are you on?
and where didya put the silica gel and how many packs and didya put in with it packed in the white paper?
And my comp is just 3 months old. It shudnt be happening
Old 07-08-2011, 03:14 PM   #15 (permalink)
Dust in the Wind
Skud's Avatar
11.8 preview, but the problem was on earlier drivers, don't remember the version.
Silica gel one packet, quite a bigger one.
Gaming Rig:
HTPC Rig:
Old 07-08-2011, 03:30 PM   #16 (permalink)
Pirate Slayer
Cool Comps's Avatar
oh.
but i nevr had the problem on catalyst 11.5
shud i uninstall 11.7 and install 11.5?
and didya just leave the silica in there?
and did it help?
thn i mite do this
Old 07-08-2011, 04:21 PM   #17 (permalink)
Dust in the Wind
Skud's Avatar
I have already stated, despite having the Silica gel, I face the problem a couple of times.
Gaming Rig:
HTPC Rig:
Old 07-08-2011, 04:23 PM   #18 (permalink)
Default Re: Monitor displaying "No signal detected" even though computer is on
On those occasions when you don't get a display, does it display the POST screen? If it doesn't even show the POST screen, then it's not a driver problem.
pimpom is offline   Reply With Quote
Old 07-08-2011, 04:36 PM   #19 (permalink)
Pirate Slayer
Cool Comps's Avatar
but what catalyst version dya have?
Old 07-08-2011, 05:06 PM   #20 (permalink)
Dust in the Wind
Skud's Avatar
Kindly look before posting, I have said: 11.8 preview.
Gaming Rig:
HTPC Rig:
Old 07-08-2011, 06:14 PM   #21 (permalink)
Mmmph!!!
doomgiver's Avatar
is this the video error week or what? im getting the same error.
i think both our motherboards' display have died (mine has been having video problems for over 3 months)
i dont know about you, but its time for a new mobo for me.
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 07-08-2011, 07:05 PM   #22 (permalink)
I've been thinking the same thing although I didn't put it into writing before.
One factor that could be the common cause of at least some of the problems posted here is moisture. This is the rainy season in many parts of India and the air is saturated with water vapour. Many computer parts accumulate dust over months and years of use. The dust absorbs moisture which provides leakage paths for the sensitive electronics. Sometimes the problem is temporary and goes away when everything dries out again. Sometimes it causes permanent damage.
Old 07-08-2011, 08:28 PM   #23 (permalink)
A PC GAMER
Gaurav265's Avatar
It is not a software issue it is a hardware issue,it looks like that problem with your motherboard.
"WHY SO SERIOUS ?"
Gaurav265 is offline   Reply With Quote
Old 07-08-2011, 08:34 PM   #24 (permalink)
Stuck in Time...
Vyom's Avatar
Usually I Love Rainy reason, for the obvious reason, that it Rains!
But, at the same time, I hate moist season, since it always gives me trouble. My mobo had gone kaput two times before. And both of the time, it was in rainy season.
Anyway, @OP: Back up your data, since that problem being a mobo issue, has the maximum chance. You may have to buy a new one.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 07-08-2011, 11:33 PM   #25 (permalink)
Pirate Slayer
Cool Comps's Avatar
sorry!! ^^
BTW shud i uninstall 11.7 and revert to 11.5
Old 08-08-2011, 03:09 AM   #26 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ if you can see the the POST screen/initial bios or UEFI screen and Xp/Win7 loading thing then it's driver issue for sure and if you were fine with 11.5 then revert back to old the version - the thumb rule of updating driver is if you are not facing any issues with the games and other apps don't update to newly released driver - new drivers are not stable always
BTW, while removing driver use Driver Sweeper - get it from here
Phyxion.net - Driver Sweeper
ToPsPeEeD = FaSt BuT StEaDy
Old 08-08-2011, 12:14 PM   #27 (permalink)
I said this before, but you didn't reply. Maybe you missed my post, so I'll say it again. If you cannot see even the first display after power-on, either the POST screen or the Intel logo, then it is not a driver issue. The software Catalyst driver is not yet involved at that stage.
Old 08-08-2011, 12:25 PM   #28 (permalink)
Fullbring
Zangetsu's Avatar
Silica Gel is used to prevent from Moisture....
as per ur problem...
it might be GPU problem.
how old is the GPU?
Install CC 11.6 instead of 11.5.
Old 08-08-2011, 05:29 PM   #29 (permalink)
Pirate Slayer
Cool Comps's Avatar
I just bought all my comp parts 3 months ago!!!!!!!!!
and as for motherboard i dont think that i have to buy a new one. Its only 3 mnths old. if anythings wrong:: RMA!!!
but recently this problem aint occuring. My comp is switching on!
and earlier it was switching on somtimes and other times it wasnt.
So i guess the problem might be solved. Lets w8 and watch! haha
Old 08-08-2011, 06:39 PM   #30 (permalink)
Fullbring
Zangetsu's Avatar
Ya..keep the PC under observation
