Old 07-08-2011, 09:07 AM   #1 (permalink)
heartripple's Avatar
Question No display ........
Hello guys,
I am facing a problem of no display for last 5-6 days......
I have EVGA 9800 GTX graphic card....I have tried to attach to another DVI port of graphic card to my Monitor but no change ..then I have attached monitor to VGA port of my Asus P8Z68-V motherboard.At this time there is a display and its quite well....
So I am worried that my graphic card is dead or what?
But at boot time there is no error code beep ... so I am confused...
Please guys tell me what to do...
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout ||
Nokia N-8, Sony Ericsson C905 both rocks my world...
heartripple is offline   Reply With Quote
Old 07-08-2011, 11:54 AM   #2 (permalink)
Default Re: No display ........
It looks as if your gfx card is dead. Have you tried removing and reseating it?
Another remote possibility: Most motherboards use the graphics card automatically if it's present, but I've known a few mobos that have to be manually set in the BIOS. That is, it will keep on using the onboard video even if a graphics card is installed unless it is set in the BIOS to use the card.
I suggest you connect your monitor to the onboard output and check the BIOS to see if it's set to Auto or to PCI-E.
BTW, while trying to solve this kind of problem, it's best to disconnect your hard disk.
pimpom is offline   Reply With Quote
Old 07-08-2011, 01:25 PM   #3 (permalink)
I have tried remove and re insert the card in it worked 2-3 times....
But its not a good idea that one should have to do this for few times in a week...
In BIOS its set as PCIE/PCI
Old 07-08-2011, 01:31 PM   #4 (permalink)
Hmmmmm
Tenida's Avatar
Try to use your graphics card in another system if no success then your card is dead time for RMA it.
Tenida is offline   Reply With Quote
Old 07-08-2011, 02:56 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
Is your card showing in the device manager after booting with the VGA port of your mobo?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 07-08-2011, 03:03 PM   #6 (permalink)
Pirate Slayer
Cool Comps's Avatar
i have a problem. But its quite different.
Monitor displaying "No signal detected" even though computer is on
CPU : i5 2500 | Motherboard: Intel DH67BL | RAM: 4 gb corsair vengeance | HDD: 1 tb seagate |
GPU :Sapphire HD 6870 | PSU :Corsair TX650 v2 | Cabinet : CM Elite 430
Cool Comps is offline   Reply With Quote
Old 08-08-2011, 08:26 PM   #7 (permalink)
Yeah quite nicely........
But One thing I want to say is these problem hasn't occurred since yesterday......
Right now I am using my graphic card with no problem what so ever......
Though I will check my display card with my friend's PC
Old 08-08-2011, 08:47 PM   #8 (permalink)
Dust in the Wind
Skud's Avatar
How old is this card?
Gaming Rig:
HTPC Rig:
Old 08-08-2011, 09:57 PM   #9 (permalink)
Super Moderator
asingh's Avatar
@OP:
You would need to test the card in another system.
asingh is offline   Reply With Quote
Old 10-08-2011, 09:32 AM   #10 (permalink)
This card is 2.5 years old.......6 months of warranty is left for that card.....
Old 10-08-2011, 09:48 AM   #11 (permalink)
Dust in the Wind
Skud's Avatar
Have you tested it in your friend's PC?
Gaming Rig:
HTPC Rig:
Old 10-08-2011, 01:36 PM   #12 (permalink)
Not yet I will do it as soon as I have some time.......Sorry guys
Old 10-08-2011, 05:02 PM   #13 (permalink)
BMG ftw!!
d6bmg's Avatar
As it is still in warranty period, test it quickly, and if it is dead, go to service center. (oops, is there any evga service center in India?)
d6bmg is offline   Reply With Quote
Old 13-08-2011, 12:03 AM   #14 (permalink)
I am facing no problems for past few days...do I need to check it on other system???????
Old 13-08-2011, 12:09 AM   #15 (permalink)
Dust in the Wind
Skud's Avatar
If it ain't broken why fix it? Enjoy your moment. If problem resurfaces (God forbid), then test it in other system.
Gaming Rig:
HTPC Rig:
Old 20-08-2011, 02:29 PM   #16 (permalink)
Pirate Slayer
Cool Comps's Avatar
my problem DID re occur. I think It re occurs after every time i leave my comp on in the night to download stuff.
But that shouldnt happen. Its not my gpu since i tried with integrated gfx and it still didnt work. I dont think its my monitor. So i think the only option left is the Mobo. Gotta claim warranty i guess.
Can it be that my mobo thinks that i am in standby mode?
Old 20-08-2011, 02:34 PM   #17 (permalink)
Dust in the Wind
Skud's Avatar
Don't know. May be power settings change is triggering this.
Gaming Rig:
HTPC Rig:
Old 20-08-2011, 03:30 PM   #18 (permalink)
Pirate Slayer
Cool Comps's Avatar
what do you mean by power settings change?
btw there is a green LED lit on my mobo.
