Old 03-08-2011, 03:48 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default IDE to SATA
Ok guys, I need to connect my old IDE HDD (80 GB) to my new motherboard, Gigabyte 890GPA-UD3H. The motherboard has only one IDE slot and I already connected the DVD-writer to it. I used the supplied SATA cable to connect the new 500GB SATA HDD. This motherboard has 8 SATA ports.
How do I connect the old HDD? Do I need a IDE to SATA converter so that I can use the extra IDE cable I have and connect the one end of the SATA cable to it and the other end to the SATA port on the motherboard?
Please also advise regarding price and availability of the same.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline   Reply With Quote
Old 03-08-2011, 03:59 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: IDE to SATA
Originally Posted by abhijit_reddevil View Post
OThe motherboard has only one IDE slot and I already connected the DVD-writer to it.
Some IDE Cable has 3 connectors...so that u can connect the 2 IDE Devices using single Cable.check for the same.
Originally Posted by DeSmOnD dAvId View Post
If you don't plan on using your old HD for long, I suggest you remove your DVD-writer and connect your HD to it. When you're done, replace it with the DVD drive.
Too cumbersome task to do that...not recommended...
Old 03-08-2011, 03:59 PM   #3 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Yup, you can connect 2 devices at a time to a single IDE port.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline   Reply With Quote
Old 03-08-2011, 04:39 PM   #4 (permalink)
mithun_mrg's Avatar
But u have to set the jumpers of the drives in master slave mode if u r connecting it to a single IDE cable
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 05-08-2011, 04:48 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
DVD drive usually sits on the top and IDE cables supplied with mobos has 3 connectors.
Set the DVD Drive as Slave ( use the jumpers on the back of DVD drive to do so ) and connect the blac connector of the IDE cable to the DVD drive.
IDE HDD jumper usually comes with either cable select mode or Master mode jumper setting - if it's in cable select or CLS mode ( look at the back/rear of the HDD to confirm ) then just connect the grey connector of the IDE cable to the HDD.
Now connect the Blue connector of the IDE cable to the mobo. This config should work just fine
ToPsPeEeD = FaSt BuT StEaDy
Old 05-08-2011, 02:10 PM   #6 (permalink)
Manchester United
Thanks. I will try that.
Old 06-08-2011, 05:03 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ you're welcome and do post the feedback
