Old 02-08-2011, 10:11 PM   #1 (permalink)
Whompy Whomperson
Nipun's Avatar
Unhappy System restarts on shutting down!
My old PC- a Pentium 4 restarts itself when I shut it down. I have tried reinstalling Windows(XP then XP again then 7 then XP then 7 again and finally XP now!!!). What could be the problem?
Its a P4 with 1GB x 2 DDR2 RAM(Even caused problem on a 512MB stick), some cheap PSU and I dont know anything else
If I unplug it when the computer shuts down(immediately before restarting), would it cause any problems?
¯_¯_¯_¯_¯_¯_ I am a peaceful NPC ¯_¯_¯_¯_¯_¯_
Need some suggestions/comments:
▒▒ Team Fortress 2 Comic Maker ▒▒
Nipun is offline   Reply With Quote
Old 02-08-2011, 10:27 PM   #2 (permalink)
Default Re: System restarts on shutting down!
There can be many reasons for this. Try the following and see if it works. It's not a final solution, but it may help indicate the source of the problem.
Right-click My Computer, then the 'Advanced' tab. Click the 'Settings' button under 'Startup and Recovery'. Then under System Failure, untick "Automatically restart"
As to your closing question: No, it won't do any harm if you time it correctly. But if you switch off power while the hard disk is being accessed, then the HDD may be damaged.
pimpom is offline   Reply With Quote
Old 02-08-2011, 10:29 PM   #3 (permalink)
Manchester United <3
Ishu Gupta's Avatar
That's for BSODs?
Faulty power supply or bad earthing?
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 02-08-2011, 10:42 PM   #4 (permalink)
^ Those and other things. There are many possible causes for the OP's problem - driver problem, buggy software or hardware, even condensed moisture at some critical points on the motherboard.
Old 02-08-2011, 10:49 PM   #5 (permalink)
Ishu Gupta's Avatar
Don't think its a software issue.
Old 02-08-2011, 10:53 PM   #6 (permalink)
Try installing Ubuntu 11.04 32-bit.
Old 02-08-2011, 11:05 PM   #7 (permalink)
@Ishu Gupta: I didn't say it's the OS.
Old 02-08-2011, 11:07 PM   #8 (permalink)
Ishu Gupta's Avatar
If you re-install the OS then don't you have to re-install softwares and drivers as well? And I don't think the OP will install all drivers and softwares every time before he tries a restart.
Old 02-08-2011, 11:30 PM   #9 (permalink)
Read your own post again. Don't you think the two sentences contradict each other?
Anyway, did you miss the part where I included hardware as a possible cause? Even moisture?
Old 02-08-2011, 11:41 PM   #10 (permalink)
Ishu Gupta's Avatar
Not at all.
First part meant that he reinstall every software/OS/drivers so they are not the issue.
Second part meant that he was probably restarting between the OS reinstall and driver/software install. So you can't say that he was "reinstalling faulty drivers" again and again.
So it doesn't contradict the first part. More like builds on it.
No. I was just saying that its probably not a software issue and we should prioritise on finding/fixing hardware faults.
Old 02-08-2011, 11:48 PM   #11 (permalink)
lol, much ado 'bout nothin'?
Old 02-08-2011, 11:52 PM   #12 (permalink)
It's best to keep considering all possibilities. He could well be installing the same corrupted files again and again. I'm not saying that this must be the reason, but it's still a possibility. And we don't know everything the OP did regarding hardware or software. In cases like this, he may not even remember them all.
Got any suggestions?
Old 02-08-2011, 11:55 PM   #13 (permalink)
Mozilla Rep
sygeek's Avatar
Did you try booting up in safe mode and see if the problem persists?
Also, try restoring to a point before this problem.
sygeek is offline   Reply With Quote
Old 03-08-2011, 12:00 AM   #14 (permalink)
Ishu Gupta's Avatar
That's the reason I put in that second sentence.
Already gave a possible problem.
I'm bored
Old 03-08-2011, 12:18 AM   #15 (permalink)
Super Moderator
asingh's Avatar
Used to happen to a friend too. Bad PSU it was.
asingh is offline   Reply With Quote
Old 03-08-2011, 11:33 AM   #16 (permalink)
mithun_mrg's Avatar
Since it is happening in win7 as well as Xp is does not seem an OS issue Try to load BIOS defaults & see
also try these
Windows XP restarts when you try to shut down your computer
Windows XP restarts unexpectedly or restarts when you shut down the computer
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 03-08-2011, 11:45 AM   #17 (permalink)
Hmmmmm
Tenida's Avatar
Ram or PSU might be faulty.Try to check with your hardware technician.
Tenida is offline   Reply With Quote
Old 03-08-2011, 03:20 PM   #18 (permalink)
Whompy Whomperson
Nipun's Avatar
RAM is not an issue, as it even caused earlier and and now with new ones also...
also try these
Thanks for the links but I already looked at them but it helps
hmm.. But I dont want to change PSU of a computer that will automatically die in 1 years.
Thanks anyways.
I will try it in safe mode.
But I dont think restoring is possible as I have reinstalled windows many times(for many different problems )
No way!!!!
Old 03-08-2011, 03:46 PM   #19 (permalink)
Fullbring
Zangetsu's Avatar
@Nipun: Its time to say goodbye to old mama..P4
its a PSU which is faulty...
Old 03-08-2011, 04:17 PM   #20 (permalink)
Mozilla Rep
sygeek's Avatar
Either buy a new system, or keep it this way.
Old 06-08-2011, 11:37 AM   #21 (permalink)
Technoholik !!
Tech&ME's Avatar
@Nipun
I think the problem is with the cabinet (hardware issue).
The power button or Re-Start button is malfunctioning.
If you have any spare Cabinet try to use it. (Re assemble all the parts or just use the Power Header wires from the spare cabinet. )
-Keep the spare cabinet close to the one with you old one. Now only put the Power Header wires and reset header wires from spare one to your mobo in the old cabinet.
- Use the space cabinet power button to start your computer!!
N.B : Above steps are for diagnostic purpose only.
Hope this sorts out your problem, if so, just replace the wire or use the spare cabinet.
[Desktop]
[Laptop]
Tech&ME is offline   Reply With Quote
Old 06-08-2011, 02:38 PM   #22 (permalink)
QUAD USER
ashok jain's Avatar
Originally Posted by Tech&ME View Post
@Nipun
Yes its may be the reason , one of my friend had face same issue with Cabinet Switch , Due to faulty Switch the system getting restarted or getting shutdown .
ashok jain is offline   Reply With Quote
Old 07-08-2011, 01:42 AM   #23 (permalink)
BMG ftw!!
d6bmg's Avatar
Check your PSU for faulty ATX/Motherboard cable. Most of the cases the reason is faulty psu.
d6bmg is offline   Reply With Quote
